We have an original fan. Two of the blades have chips out of them. Is it trash?
Scrap Metal or this may happen https://www.flickr.com/photos/2010-2011_european_tour/albums/72157644084433382
I was at idle, just engaged when i heard a nasty clunk. Best News, I wasn't at speed when it broke. I've heard of Fans at speed Destroying the back end/ engine Replace It, hang on garage wall. |
Thanks for sharing some real world experience and photos. |
It still useable
Rey....77 930 "the Mistress" |
The 9 Store
Ben / MB911 fixes them. He welds mag, alum, etc. he’s done dozens if not more.
All used parts sold as is. |
I dont see how a chipped fan blade results in a sheered alternator shaft but do what you will.
82 SC , 72 914 |
An out of balance fan can cause damage from vibration. If solid except for the chip it can be fixed and re-balanced.
The problem is if it has deeper corrosion. I can't really tell from the photos, it needs to be examined a bit closer. As you can see in this picture, sometimes magnesium corrodes too much to be fixed.
Ed 1973.5 T |
It's a 914 ...
Welding a chip, done by a competent expert, and the fan in the last picture above, are very different things that should not be compared.
![]() This chip has been missing for over 20 years. I’ll let you know if the fan explodes and destroys my engine. Sent from my iPhone using Tapatalk |
I have a similar size chip in one of my blades also. Also has never been an issue in 20+ years and can't sense any imbalance thru the rev range.
Walt 82SC 3.0 81SC 3.6 |
Exactly my point.
Full Send Society
Just chip the opposite blade and you’re now balanced; all good!!
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Clean it up & have it crack checked. I don't think that chip will put it noticeably out of balance. Run it.
Probably worth replacing in the near future. 🫣
