Rear speaker size
is 4X6 the standard OEM size for the rear speaker covers? 85" 911 coupe
Yes, 4x6 max 2" depth.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
thanks! lobster interior? bet it’s cool
I replaced my factory speakers that had tiny magnets and paper diaphragm. I couldn’t get the speaker to nest in the cavity. I ended up using two sets, with the lower inverted. That raised in up about an inch.
![]() ![]() The Guards Red line is a rubber-band.
Senior Member
JBLs fit direct drop in
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
jbl’s and factory covers?
Senior Member
JBL 6421F, from Crutchfield, $80 a pair. Acceptable sound, used Focal in front, they look stock. You can get VERY original looking covers on Amazon for 15 bucks. Mine were ok, but the mounting base after 34 years crumbled. Those were avail direct from Porsche and weren’t horrible. If you are a base guy you’ll be a little sad, but sounds much better than stock. Plus it’s a Targa…a $4k stereo would be a waste.
found these
did the covers from Amazon fit flush to the deck or did they sit high? Found only one 4 x 6 pair... they looked like they where high, about 1/2 inch not flush.
Senior Member
They are very close to the exact dimensions and look of original. My factory speakers are maybe 1/2” above deck.
ok great thanks for your help
Senior Member
I’ll take a picture today
Senior Member
Senior Member
In the above picture bottom is 34 year old OEM the top is the Amazon version…
![]() PN: 911-555-019-00, $104.00 on PP Lists years used as 1978-87 Last edited by porschedude996; 11-12-2022 at 12:38 PM.. |
Titanium User
Late 87 and up went to the 1/2in tall rear cover. Everything before that was the flush grill cover.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Senior Member
Dude - the screw pattern and shape appear the same, on the 88 it is two parts, there is a base plate that is brittle after all of the years and disintegrates, and the cover. Dealership was surprisingly fair on price when I looked. I did not realize these had changed, my early 87 had the same.
mine are less than 1/4"
Polk EX346 speakers
Possibly why my covers cracked immediately after install..They are too high and pushed again the cover.
Looked on Crutchfield and these Polks are listed as "DOES NOT FIT YOUR VEHICLE" Guess the seller years ago didn't do any research.
