OEL Gage ????
my OEL gage on my 77 911 is not working ? ... . should I drop the oil tank and replace the float? ... is it a big ordeal when I change the Oil ? ... I am a new owner and when I was looking for a 911 many of the OEL gages were dead . the car has a newer (45K) 3.0 .... does this make a diffrence? Also temp runs at 215 deg .... what temp would indicate a problem ....
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 08:23 PM
ruf-porsche's Avatar
Run the car until it is at it normal operating temperature, remove the oil tank cap and pull out the dipstick. If it is between the two marks the oel level is fine. If it is below the lowest mark, you need to add oel. The oel gauge should indicate the oel level when the engine is hot and there is a correct amount of oel in the tank. If not it might be a bad connection or as you said the float might not be any good.
When the temperature gauge is in the red zone than it too hot and you should stop the car and let it cool down. Also check to see that the fan belt for the fan isn't broken.
Old 05-30-2003, 08:34 PM
andrew15's Avatar
- While its a bit difficult to access, the oil level float can be replaced without dropping the oil tank.
- Keep in mind that the gauge is only accurate under specific circumstances.
- You should get a copy of '101 projects for your Porsche 911' It's authored by Wayne (host of this website) and will be an invaluable asset in the care of your car.
Regards,
Andrew M
ro Being new to the
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 05-30-2003, 08:35 PM
lateapex911's Avatar
I was under the impression that those guages impressed no-one with their accuaracy.......and most guys take a perverse pleasure in the aquired knowledge required to manually check the level. At least that's what I tell myself, as mine is a bit scitzo sometimes!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-30-2003, 08:53 PM
thanks for the reply .... my 77 has no red zone on the gage just deg marks 210,250 ect .... sounds like a real hassel removing the float with the tank in the car ..... looks like the 101 book will be a must ... I guess mobel 1 is the oil from what I hear ... but very $$ .... what weight do you think I should run in Wa. State were we rust insted of tan.. thanks
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 08:56 PM
nostatic's Avatar
that's the oil temp guage, not the oil level guage.
Unless there already is synthetic (ie Mobil 1) in the car, stick with regular dino oil. The lore is that switching to synthetic on an older engine is asking for new oil leaks. In SoCal I run 20W50, so maybe in WA 10W40?
Old 05-30-2003, 09:00 PM
it's no big deal.. the sender comes with a cork gasket.. order the up-grade rubber gasket with a seperate part number...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2003, 09:03 PM
good post on the float gasket ... first I will check for power at the tank..Im not sure what oil is in the car now .... so should I switch to mobil1 or what ? ... but what should the car run under nomal 70 deg day ? .... also I hear you on pulling the dip stik first befor reading the OEL gage
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 09:21 PM
nostatic's Avatar
my oil level guage actually seems pretty accurate. The trick is that you don't get a reading until the engine is at operating temperature and the car sits at level idle for about a minute. But when my needle no longer rises out of the red, I know I'm about a quart low. I double check with the dipstick regularly, but so far the guage actually gives some info.
Old 05-30-2003, 09:25 PM
is there a radiator or brass loop under the right front fender?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2003, 09:26 PM
no ... just a set of horns ..?
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 09:40 PM
Cool
that means there is not a brass loop on the luggage compartment outer wall.. or a small radiator foreward of the tire?? you gotta confirm your last post.............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2003, 09:45 PM
none that I an see .... should there be ??? mabe Im not looking it the right area .... are you talking about an oil cooler ?
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 10:10 PM
if you don't have an oil cooler your limited in exercising the engine.. and a full install is big bucks.. dam.. how about some history on this 911.. like you have a nice engine.. but the install isn't completed.. you got one good thing going for you tonite.. and that's living a few miles away from the best 911 financial manager on this site.. his trade name is Superman.. he stretches nickels into dollars for entertainment..
So, any cougars in your area? I drove by your town last June .............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2003, 10:24 PM
there is alot of paper work on the car and Im not sure of what you talking about ...so ...I should run an oil cooler on this car??..... did a 78/79 3.0 have a front oil cooler ? ...I just need some basic info on keep this car running and learn how to keep the cost down ..I have records on the car from 1980 ...3rd owner ....
Jimbo
77 911S
77 MGB
69 Roadrunner
65 Coronet
85 Teenager
Old 05-30-2003, 10:41 PM
Your temperature seems okay. Read this previous thread on how hot
Engine Temperature
Old 05-31-2003, 05:04 AM
It sounds as if you are combining two different things. Are you having a problem with the oil temp gauge or the oil level gauge?
Old 05-31-2003, 08:11 AM
He's just a newbie and asked 2 separate questions in the same post.
He wanted to know about the oil level gauge and what temp his car should be running.
Old 05-31-2003, 08:54 AM
fred cook's Avatar
Cool Oil Level Gauge
Replacing the float mechanism for the oil level gauge is not difficult. Just be sure to throughly clean the outside of the tank before removing the old sender. The wires for the oil sending unit work through the right rear taillight assembly harness, so be sure to check the chassis electrical connection that is just inside the engine compartment, right side just below and behind the oil filter. Also, don't over tighten the fasteners that hold the oil sender to the tank.
Good Luck!
Fred Cook
'80 911SC coupe
Old 05-31-2003, 06:27 PM
HarryD's Avatar
Hello,
For oil, I use 20W50, I drive it mostly in the warm months but I never put the car to sleep so on nice winter days, we will go for a ride. I see no problem witht he heavier oil. I am currenlty using Vavloline (what my wrench uses) but I have also used Castrol and the PO used Kendall.
As far as the gauge, my gauge reads in the red zone when I am about 1/2 quart from the min point on the dipstick. Seems pretty reliable.
I also noted your comment about a lack of an external cooler. Are you sure there is nothing in the front passenger fender well and a couple of brass lines going to them from the engine?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-31-2003, 06:51 PM
