Cleaning Engine
Going to detail the engine area on my 68 and remove all that old grease and dirt. Does anyone have any tips on cleaning the engine area, specifically what products to use on the all the rubber? Should I use a degreaser or just good old elbow grease? Anything I should avoid or be careful of?
Senior Member
Don't be shy, unless you want this to take many many many hours. Take it to a car wash and pressure wash the poop out of it. Or better yet, get it steam cleaned. After that, your detailing job will be easier.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
there are a couple of tech articles on cleaning/detailing your engine compartment that are very helpful
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
I got the stubborn spots out with a toothbrush and some mineral spirits/paint thinner... (New concept for tooth whitening?)
Kris - '77 911S |
Hilbilly Deluxe
This stuff is the she-it.
![]() Tom edit: bigger picture Last edited by emcon5; 05-30-2003 at 04:27 PM.. |
Bandwidth AbUser
Tom, where do you get that she-it?
Jim R. |
That she-it is at pep-boys. I like it too, but it says it is not to be used on paint. I find that Simple Green works great and will not harm the paint. It will also please the tree huggers.
Hilbilly Deluxe
It is a Castrol product, I get it at the local auto parts chain, but you should be able to find it damn near anywhere. I know Wal Mart has it, and I think I have seen it in grocery stores.
It is "Biodegradable and phosphate-free, non-abrasive and non-flammable." Tom |
A few weeks ago, I removed my alternator and noticed that I could not see the fins on the tops of my heads or cylinders
. I used a few cans of Gunk Engine Brite to clean that stuff off. Engine seems to run a bit cooler. You should consider cleanng this area as well as the outside of your engine.
19 years and 17k posts...
Simple Green and hot water!!! Works great on grease/dirt, etc....
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Simple Green!!!
I don't dilute it, use it full strength and rinse with hot water before and after spraying it on.
P21S Auto Wash. Unless you _want_ to use all that cheap she-it.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
How about waterproofing the electrical stuff? I want to do my SC and I would expect that I should plastic bag some stuff in the engine bay to keep water off of it. Maybe I don't need since none of you have mentioned it yet.
we all know to do this. thanks for keeping us on our toes.
The last time I used Gunk it turned left a white film on all of the aluminum parts. Use the she-it referenced above.
1987 Carrera, Guards Red, Black (sold but never forgotten!) 1965 356SC Coupe, Silver on Red |
Another good product is the engine degreaser sold by Griot's Garage. It works really well and does not have noxious fumes. A bottle of that, a high pressure sprayer, and a few cans of brake cleaner will do a good job. Be careful with the Gunk degreasers because if you get any on a plastic or rubber surface and do not rinse it off thoroughly, it will eat through the surface. Ask me how I know.
Well,
No more gunk for me. Don''t want to find out if these horror stories are true.
Hbrand
If you really want to clean an engine, you have to : disconnect battery, remove fan, alternator, carburettors and fan shroud. Then you need to put a lot of towels into the intake manifold.
Then you vacuum all the stuff between the fins AND the OILCOOLER! then you flush. After you cleaned and detailed then you can reinstall all the parts taken out. this takes only one day. thanks, harold
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
Yeah, don't breathe the vapors from that Sheez-Nit. I squirted a whole bottle on my 901 trans yesterday, it does the job well (with some agitation to take off the caked on stuff) but will irritate your eyes, lungs and stings exposed skin. Not QUITE in the same way that brake cleaner will, but be careful.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
