-   -   Missing hub thrust washer? (http://forums.pelicanparts.com/porsche-911-technical-forum/1130199-missing-hub-thrust-washer.html)
TeeJayHoward 11-19-2022 06:08 PM
I took apart my driver's hub to replace the rotor and realized that there was no thrust washer installed. The bearing was directly sitting on the clamping nut.
https://i.imgur.com/zv5o88Cl.png
Crazily, I haven't noticed any issues with the car. But now I've got the replacement rotor installed and I'm freaking out a bit about reassembling it without it. Is this the kind of part my local dealer would have in stock or is it more of an "order one" thing? Are they typically replaced when you swap in new bearings or re-used?
Reiver 11-19-2022 07:00 PM
Put the washer in place....you set the load on the bearing using the washer. It is a thick washer but you could source one just about anywhere if you had one to match it too.
john walker's workshop 11-19-2022 07:38 PM
The proper thrust washer has a tooth that goes into the groove in the spindle, which keeps it from spinning, so you need the real one.
Reiver 11-19-2022 08:56 PM
Forgot about that part.... luckily we have guys that do this for a living here...
gled49 11-19-2022 09:26 PM
Again, we need to know model year as there are 2 sizes of the thrust washer.
smadsen 11-19-2022 10:00 PM
That T-washer also helps keep the grease packed in the bearing, in the bearing. While you can get the bearing pre-load adjusted properly w/o the washer, that's not the method for optimum longevity.
TeeJayHoward 11-19-2022 11:09 PM
Mea culpa, it's an '81 SC. I believe it's part number 911 341 663 00. I've got one on the other side I could use as a template to create a new one from scratch, but I don't have the proper thickness of metal laying around. I have every intention of purchasing a new one, I just need to know if it's the kind of thing I can pick up without waiting at the dealer, or if I should order online.
My dealer won't open until Monday. I don't live in CA where you can pick one up from a junkyard same-day... Just trying to find the method which'll get me the washer the quickest.
H-viken 11-20-2022 02:57 AM
Where do you live? With a bit of luck you’ll have another Pelican nearby who can help out
Arctic Rat 11-20-2022 04:25 AM
A new one is $7.........just order one?
