911 flywheel metal sensor
Hi All, I hope you can help me with this. I just replaced clutch, and re-machined the flywheel. But it does not start - no spark at all. So I think it might be that the machine shop removed the metal "stud or bolt" that" triggers the ignition. I am hoping that I might be able to "see" the stud/bolt from one of those access openings (where the sensor units are or down below). Can any of you provide insight on this?
If not, then I'll have to drop the motor and trans again. Ugh...Thanks...CLIF |
lake wales fla
If you remove the reference mark sensor (the one closer to the engine block) and watch with a very bright light while someone slowly turns the engine by hand you will be able to see it. There is no reason that should be removed to surface the flywheel but hey I am sure we have all had our episodes with machine shops. Don’t want to question your knowledge but are you sure you did not mix up the connections in the engine compartment with the speed sensor.
Richard |
Diss Member
If the dowel is still there check it with a magnet. There have been some with a non magnetic stainless dowel and that doesn't work.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks guys. I agree with Porschyard that I should double check the wiring first. In fact, the wires themselves look kinda wonky so was thinking of simply replacing them anyway.
ahead of the curve
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
lake wales fla
Richard ![]()
