2017 991.2 Base Steering wheel airbag retaining Frame
I am attempting to upgrade my steering wheel. I am having trouble removing the airbag retaining frame. The 3 torx bolts are locked in place, and I am afraid of striping the heads. Does anyone have any experience removing these? I have tried heat, impact, tapping to wake them up, and plain old force.
Old 11-22-2022, 08:49 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Try Using an impact gun with all of your weight on it..
Marc
Old 11-22-2022, 08:05 PM
As a last resort, maybe cut a groove across the heads and use a large screwdriver? You're getting close to needing to drill them out, which isn't the worst thing, I'm sure you can find the torx bolts.
Old 11-23-2022, 06:55 AM
