'73 911 T Targa
Cleaning new gas tank
I just got a new Dansk tank. In the item description, it says it should be cleaned of manufacturing debris before use.
Does this about to just putting the strainer on and sloshing around a quart or so of gasoline and then let it drain out and clean the strainer? I don’t hear any loose stuff rattling around in there… |
From what I've read it's about cleaning out the preservative.
Cleaning new Dansk, J/P group fuel tank before first use Here's a recent discussion on this. Dansk gas tank pre cleaning |
Good luck. Killed a fuel pump after rinsing the last dansk tank quite well. 1/2 hour down the road it ingested a particle that seized the pump. No room for a pre- filter really, so you have to invent something.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-27-2022 at 12:31 PM.. |
No issues using the Delphi FC01 Fuel Tank Cleaning Kit from Amazon. Used a compressor to blow it out immediately then rinsed with fresh fuel. No flash rust and no issues.
Also, one of the industrial radiator shops does cleaning of gas tanks.
'73 911 T Targa
My Dansk tank has a strainer, so hopefully I’ll avoid a fuel pump tragedy.
I just recieved my new Dansk tank. Plan is to rinse it out well with white vinegar. Then rinse with water and then isopropyl alcohol followed by air drying.
