Nadella Lubrication?
Any recommendations for lubricating my vintage Nadella half shafts?
PCA Member since 1988
Any CV joint lube with Moly in it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Do they have to be disassembled?
If you mean totally disassembled, then no. You do have to get the grease into the boot and end of the joint. Why are you lubricating them? They should still have plenty of grease in them, unless you cleaned them for some other reason. .
Navin Johnson
Nadella half shafts do not have a boot, they are a u-joint similar too what is used on driveshafts of domestic cars
https://www.gunnarracing.com/project/906-127/05-26-05/906127-052605.htm ![]() You can get an idea how to proceed from this video
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thx Tim.
Dang I thought Nadella was something you smear on your toast
That's Vegemite.
Interesting that the video suggests lubricating joints at every oil change. What a PITA! Granted these aren't the Nadella type I hope
Navin Johnson
The Moog/Spicer/other u-joints sometimes have a zerk fitting, or the provision to install a zerk.. I havent seen a Nadella joint for many years, and don't remember if a zerk can be added to them..
On the Moog joint all it takes is a squirt with a grease gun.. until some grease comes out of the joint.... easy to do while changing oil.. Its a bit of a chore to manual break down and grease the joints though
