Which tool to remove these connectors
Have all these tools but which one will do it? Or is there another?
Trying to remove spade connectors from a mirror control switch harness. 1985 911 they still wont tilt! http://forums.pelicanparts.com/uploa...1669563041.jpg http://forums.pelicanparts.com/uploa...1669563041.jpg |
Nothing special.
Use a very small flat head screwdriver to depress the tang and pull out the connector. The "tang" is on the other side of the spade connector your picture is showing. |
The back side of spade connector should have a small tab that you need to press while pulling the wire.
Use a tiny flat blade screwdriver or one of these connector removal tool kits found everywhere (amazon, bay, aliexpress, etc.) |
think I tried them all!
Eye glasses screwdriver set, tiny little one.
Like all said, small flat screw driver.
Sometimes the tab is stuck to the connector, you have to push it from the back and then insert the screwdriver to flatten the tab and then pull. |
got it!!
now I have to figure which wires connect from switch to harness to mirror...different colored wires coming from harness from what is going to mirrors!
nightmare!!! tired of changing burnt fuses and diodes from inside the mirrors. Quote:
http://forums.pelicanparts.com/uploa...1669653501.jpg |
| All times are GMT -8. The time now is 06:42 AM. |
