Fuel Line Upgrade vs Tunnel Holes
This may be a dumb question...
I have a '75 911S that I bought fully disassembled. And the first time I drive a 911, it will be this car. So I'm a noob. I'm working my way through everything that needs to go in the tunnel and I have a question. When the fuel pump was in the engine bay the two fule lines (supply and return) were different sizes but now that the fuel pump is going to live up front the fuel lines (and associated grommets are all the same size. The holes in the tunnel are sized for the old set up. Is there an easy / clever way to enlarge the smaller holes? Should I just drill it out? They are nicely flared now. Thanks! The knowledge in this forum is amazing!
Zach 1975 911S |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Zach 1975 911S Last edited by zprovo; 04-22-2024 at 08:06 AM.. Reason: added Thanks |
Good luck pulling those lines. I replaced mine a few years back and it was a bear. I hope they go in easy for you.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
