dist. to throttle body vac. lines
1980 911 sc, there are two vac. ports on the back side of throttle body, one above the butterfly and one below. one has alot more vac. at idle the other has slight vac. also theres a port between the air box and the CIS intake boot [WUR ?] which goes where in relation to the dist.i dont know which connection is advance and which is retard on the dist.
Just to take a stab in the dark due to logic. Your ignition should retard due to load, meaning that if the intake pressure goes from vac, to atmosphere, your on WOT. So this would tell me that you want the retard side connected to the one closest to the intake, and the advance would be the other one. But i'm not sure so don't take my advice too seriously.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
