-   -   Clocking a turbo?? (http://forums.pelicanparts.com/porsche-911-technical-forum/113118-clocking-turbo.html)
lendaddy 06-02-2003 07:50 AM
Clocking a turbo??
I believe that is the correct term for turning the cold side of turbo on its axix. I would like to turn the cold side counter clockwise to better line up with my pressure pipe and am not sure if this is wise. This is a K27 and does not have the compression ring that holds the hot/cold sides together on a K26 rather it has a series of small bolts with tangs that hold them together. Did that make sense? If I loosen these and turn the cold side CCW what torque to I use to tighten these back up? Do I have to worry about unseating a seal or something? Thanks guys
john walker's workshop 06-02-2003 08:23 AM
commonly done. no problem.
lendaddy 06-02-2003 08:24 AM
Thanks John, any idea on the torque for the bolts?
cowtown 06-02-2003 08:24 AM
I backed the bolts off about 3/4 turn and then tightened them using my calibrated eyeball. I set the torque to "snug," as used with valve covers.
Mine had no gaskets. It was metal-to-metal.
