911 Bell housing pattern(s)
I saw a technical drawing of the common 911 bell housing pattern including measurements. Can't seem to find it anymore.
I believe it has the 4 studs and the starting mounting. Needed for a CAD project / design. Anyone have this? Thanks! |
Found this from another forum, appears to be accurate
The bell location diameter is 281.9 mm x 4 and the 4 bolt holes of M10 from the centre are XY 104.5, X-104.5 Y 104.5, X 99.06 Y-109.86, X-99.06 Y-109.86 this is for upside down trans ---for right way up just substitute +,- Just doesn't have the starter second stud or offset from engine block |
