Good source for oil and vacuum hoses
Is there a good source to buy various hoses to
replace the hard and leaking ones? Thanks |
Belmetric
it's not leaking....it's just marking it's territory |
How to determine which type to use for each application?
I found good hose products here at Pelican when I redid mine:
https://www.pelicanparts.com/byb-contitech/c-engine_c-engine-miscellaneous_c-vacuum-hoses-lines |
PCA Member since 1988
It depends on which hoses. The big oil hoses you're probably best to buy from a Porsche parts seller, like our host. Smaller hoses you can buy from the local auto parts stores and not have to go through the shipping/waiting routine. Those won't have the braided fabric exteriors, but if you're not concerned about original appearance, they are fast and cheap. If you want the OE stuff, order online.
![]() If you need Fuel or Oil Lines or Hoses that are NLA (No Longer Available) from Porsche or our Host, I may be able to help. I have the correct E-85 Rated Fuel Hose and the correct Porsche Oil Hose to "Re-Hose" or make up just about anything you cannot buy as an assembled part. I do not offer Lines or Hoses that are still available through Porsche or our Host. For information, please email me only. No pms, my box is almost always FULL. len.cummings @ verizon.net Thanks for looking. Len
