-   -   Light in Heater Control Unit (http://forums.pelicanparts.com/porsche-911-technical-forum/1131492-light-heater-control-unit.html)
bmcfarland 12-15-2022 05:48 AM
How is the light bulb in the heater control unit accessed / changed?
http://forums.pelicanparts.com/uploa...1671111935.jpg
http://forums.pelicanparts.com/uploa...1671111955.jpg
wazzz 12-15-2022 06:32 AM
Thru the side flapt labeled 3 on the diagram. Remove it with care and you should be able to reach the bulb inside.
wazzz 12-15-2022 06:33 AM
Thru the side flap labeled 3 on the diagram. Remove it with care and you should be able to reach the bulb inside.
bmcfarland 12-15-2022 06:39 AM
Thank you, wazzz!
bmcfarland 12-16-2022 08:31 AM
Has anyone attempted to remove the four bolts and, assuming the wiring is long enough, lift the heater control housing high enough to get access to the bulb?
I found this photo on the internet and circled what I think is the bulb holder (black-blue illumination primary wiring has been removed). Given its position, access via side hatch requires seat removal and access is blind via removal of the rubber boot covering the emergency brake.
http://forums.pelicanparts.com/uploa...1671208139.jpg
Bucketlist 12-17-2022 04:41 AM
Here are a couple of pics:
I would pull the passenger seat, the 4 mounting bolts to raise the assembly. Then remove the 4 side cover screws. Remove the knob from the top and slide the cover off and you will see the bulb (blu/w & brn wires) which slides into a hole in the switch.
http://forums.pelicanparts.com/uploa...1671280072.jpg
bmcfarland 12-17-2022 05:04 AM
Thank you, Steve!
bmcfarland 12-26-2022 07:57 AM
Thanks again to wazzz and Steve for their guidance. Closing this loop:
1.) removed the passenger seat per Bentley Service Manual page 720.
2.) removed access panel from right side of heater control housing.
3.) using a pair of needle nose pliers, was able to easily remove the lamp assembly from the housing socket without having to removed the entire heater control housing.
4.) removed old bulb, replacing it with a new, readily available 12V, 1.2 watt bulb.
5.) installation reverse of removal.
http://forums.pelicanparts.com/uploa...1672070153.jpg
