SC sunroof air deflector springs
![]() 79SC with old style air deflector and the ends of this wild looking spring broke off (on both sides) right where they fit into the hinge strap that holds the actual deflector lengths. Spring ends should be about a half inch longer with a small hump that jams into the hinge strap. How its secured is unknown? Research here identifies a European vendor that sells the parts individually https://nl.parts-wise.com/90156407500-911-(65-82)-veer-voor-schuifdak-windspoiler,-2-benodigd-per-schuifdak./p247073/ Are there any other creative fixes for this problem? Pelican sells the whole air deflector assembly but the parts from Europe are a much more reasonable fix What are the recommendations from the Pelican Brain Trust? Thanks ahead ahead ![]() |
