Feedback on Maxilite 8" Wheels - Excellent Quality!
I installed Maxilite 16"x 8" wheels from "Fixer".
Quality is excellent and he's a great person to do business with. Transaction was simple and I received the wheels three business days after payment through Paypal.
I moved the 7's to the front and the stance is perfect. I'm running Michelins 205 / 225. Also, my original center caps fit with no issues.
I would highly recommend these wheels.
Old 10-14-2019, 03:41 AM
Fixer's Avatar
Thanks,
That was a good idea, I'm glad you're happy ! The stance looks perfect.
What model Michelin specifically? They look perfect for my current build.
Matt
Old 10-14-2019, 04:16 AM
WayneY's Avatar
Looks great! Wanting to do the same on my 86. How was the Maxilite finish compared to the Fuchs 7s?
Old 10-14-2019, 04:37 AM
Originally Posted by Fixer View Post
Thanks,
Matt
I went with Michelin Pilot Exalto PE2 (Ultra high Performance Summer). They are great so far.
Old 10-14-2019, 06:43 AM
Honestly I can't give good feedback on this one. My car sat outside for 10 years so the original Fuchs are a bit weathered but the finish on the Maxilite wheels looks great.
Old 10-14-2019, 09:28 AM
Flojo's Avatar
I run my second set of Maxilite 7/8x16 ind my 911-life.
where I roll - Frankfurt am Main
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-15-2019, 04:09 AM
WayneY's Avatar
Took your recommendations and got a pair of 16x8 from Fixer/Matt, but kept the 6s upfront. Great purchase and love the look of the 8s, now just need to adjust the height and get the stance just right.
Old 11-07-2019, 04:56 PM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
The Maxilites seem to be a reasonably good alternative. Pricing looks to be approximately $235 for 16x8. The new Fuchsfelge 16x8 is near $700.
One downside is the weight difference. 17.5 lbs for the Maxilite 16x8, vs 12.7 lbs for the Fuchsfelge in the same size.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 11-07-2019, 06:50 PM
billydeakins's Avatar
Another happy Fixer customer here too! Matt is great to deal with and wheels great!
1989 911 Carrera 3.2, Guards Red
Old 11-08-2019, 09:05 AM
Flojo's Avatar
??? where d'you get that from!
17,5 lgs= 7,94 kg
12,7 lbs= 5,76 kg
I recently got my second set and absoluteley cannot say that there is a near 2kg difference in weight per wheel for 8x16.
I measured aproximately 400 gramms.
Old 11-11-2019, 02:09 AM
Now in Florida !
Fuchsfelge 16" weights
https://www.fuchsfelgeusa.com/16-inch-satin-black/#16inchblackoptions
https://www.*************/91136211700-8sb.html.html
replace the stars in the last link to Stoddard dot com
Old 11-11-2019, 08:34 AM
When I first got my 16 x 8's (951 wheels) they came with tires so I put them on the back with the 6's up front. I thought that gave me really severe understeer.
The 16 x 7's with 225's rubbed so I put the 205's on the 7"s . Steering is a bit heavier but I am happy with the handling.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 11-11-2019, 10:02 AM
Fixer's Avatar
Another bought 8s just for the rears. Looks great imo.
Old 11-13-2019, 05:46 AM
Flojo's Avatar
may be an issue with camber toe setting.
I run 7x16/205-55 front and 8x16/225-50 rear (no spcers at all) for years now.
lowered to F63/R62cm and camber at F-1.4/R-1.05 it handles great in corners without being nervous on full throttle straights (autobahn 200-240km/h).
Old 11-13-2019, 06:00 AM
Really loving my Maxilites! They are looking great and their quality is excellent.
Old 02-04-2020, 09:38 AM
Fixer's Avatar
Here is a video on how you can in 5 minutes make the Maxilite RSR wheel look great and MUCH better than Stoddard's finish which is just the regular cheaper satin black/diamond cur wheel taped differently.
My way looks terrific and is simple and fun. The reason is that you're starting with a polished wheel, the other "proprietary finish" is not. It's just an immersion paint procedure to try and look like an anodized finish but the way I show you looks more like an anodized wheel. In fact the finish looks just like some original Fuchs made in 1970 that I have in the shop.
If you've already mounted tires on your RSR finish wheels it's simple enough to still do.
https://youtu.be/L4LY5XO8hiA
Old 02-05-2020, 05:10 PM
Flojo's Avatar
i like it… though the common RSR finish has kind of ice-ed/matt/blasted pedals and just a polished lip outer edge...
Old 02-06-2020, 02:08 AM
Fixer's Avatar
I said I only spent 5 minutes lol 😉
So tape off the outer lip and compound more and there you go . The more you compound the more iced the finish becomes.
Old 02-06-2020, 02:27 AM
Fixer's Avatar
The 17s have finally landed. I'll have the first batch in May.
I bugged Maxilite to make these and they're here. . 7, 8, 9, and 10x17s
This is excellent news!
Old 04-02-2020, 01:23 PM
Fixer's Avatar
Here's a "deep 8" I made out of two deep 6s.
I took the excessive shine off the "RSR finish" to look much better. Takes about 10-15 minutes per wheel.
https://youtu.be/ztiSe13DY3k
Old 05-05-2020, 02:43 PM
