G50 Release Bearing…is this crack supposed to be here?
We’re putting my g50 back together and having trouble mating the transmission to engine. During the process I caught that the realest bearing has a crack that kind of looks intentional. Is this supposed to be there?
Also any tips on getting the trans mated back to the engine are appreciated. We’re 1/2” away and it keep getting hung up, possibly the input shaft.
-Mike
1987 911 Carrera Coupe
Old 08-01-2023, 08:55 AM
proporsche's Avatar
1.yup no worries....2.did you use the installation guiding pin to align the clutch disc,if yes select the gear and spin the trans..
Ivan
btw..looks very dry, make sure you lube fork fingers and the inside of the TO bearing plus the 2 meeting points for the fork
look
https://www.design911shop.com/p/porsche-911-964-993-996-997-clutch-release-bearing-sachs-3151000464/?currency=GBP&country=GB&gclid=Cj0KCQjw2qKmBhCfARIsAFy8buI8ZOCI9ccAq4klC-3_Z1JYFFhvamjdOYRKjB-eLEv4pxiuR-Y0cioaAqGREALw_wcB#fancybox-619570
1985 911 with original 502 191 miles...808 198 km
Old 08-01-2023, 09:27 AM
Ivan
look
Ivan, thank you.
We did use the alignment tool and it does slide in. We’ll try the above remedies next. It’s so close…
-Mike
Old 08-01-2023, 09:51 AM
No lube in the bearing liner or on the guide tube.
206 637 4071
Old 08-01-2023, 10:42 AM
Red Line Service
Marc Bixen's Avatar
Nooooo! Lube the fingers, but DO NOT lube the inside of the T.O when it is a teflon lined bearing. Dry inside the bearing, dry guide tube, lube only the fingers and the splines on the friction disc and input shaft. That's the little lube pack that is supplied with the clutch. You only lube the guide tube and t.o. inner on all metal t.o. bearings, such as 915,901, 356 style.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Ta da!
206 637 4071
Old 08-01-2023, 10:43 AM
Lifesavers.
Line the polybronze bushings in the fork?
Old 08-01-2023, 11:15 AM
proporsche's Avatar
thanx, did not do g50 clutch for a long time
Ivan
Old 08-01-2023, 11:23 AM
Red Line Service
Marc Bixen's Avatar
So, oil lite bushings require a different type of lube. They should be pressure lubed prior to installation. We like gear oil. See this video:
https://www.youtube.com/watch?v=8z2x8mMuVgY
Old 08-01-2023, 12:17 PM
I used a motorcycle jack w a rolling base to make it easier to guide on by myself.
Lining up the four bolts could be a bit tricky if you have to lift it up to put it on.
I did have to take mine out because my sachs bearing separated at the pin... so putting the Porsche bearing I forgot I bought in later this week.
Link to bike lift: AMAZON
Old 08-01-2023, 12:43 PM
Finally got it mated. We took apart the clutch assembly, test fit it and reinstalled with extra attention to keeping the clutch alignment tool perfectly centered. That, plus a little bit of prying against the release fork got it flush.
Thanks for the help everyone!
-Mike
Old 08-01-2023, 03:09 PM
Nice!
I went out to try to get my new release/throwout bearing on.. and need to take it to a shop to get press fit... I guess I don't weigh enough to stand on it and insert the retaining hoop.
I'll try to take it to a local shop tomorrow.
GL w the install!
Old 08-01-2023, 04:27 PM
More good things to know…
Old 08-01-2023, 04:37 PM
Originally Posted by almostordinary View Post
Nice!
GL w the install!
You can probably do this solo. Once it was assembled we were able to get it pressed in with a little bit of force (less than body weight).
-Mike
Old 08-01-2023, 04:58 PM
Put it on the ground and kneel on each side. Not that hard.
206 637 4071
Old 08-01-2023, 05:03 PM
I kneeled and stood on it. I got it to clip under the retainer, but the rest of the ring still sat a bit proud on other edges. I took it back apart, how does the below look?
Old 08-01-2023, 06:33 PM
Tap it in with a hammer and small punch or screwdriver to be sure it's seated. Oh, you have the big ring upside down. That tab goes between one of the pressure plate fingers. No groove for the snap ring on that side.
206 637 4071
Old 08-01-2023, 07:50 PM
Wow, John thank you.
Flipped it this morning and barely had to kneel on it and the ring fully seated.
May be able to get my first test drive in this week now!
Thanks again.
-Ian
Old 08-02-2023, 10:07 AM
