-   -   85’ 911 front window question (http://forums.pelicanparts.com/porsche-911-technical-forum/1131999-85-911-front-window-question.html)
lada03 12-27-2022 03:58 PM
Guys,
My driver side window goes down very slowly.
It starts of slow, the first 4” it goes down. Then after that pretty much stops. I can help it with my hand to get it half way down and then it picks up speed and goes down normal speed on its own. It goes up fast like it should.
Passenger side is perfect speed. I have new window switches in both sidew
What can be done to help my window go down faster? Silicone Lube the window track?
proporsche 12-28-2022 08:33 AM
replace the window felt...would be my suggestion..also possibly frame adjustment will help
Ivan
lada03 12-28-2022 08:35 AM
Quick fix
This seemed to work, will see
http://forums.pelicanparts.com/uploa...1672245346.jpg
EC900 12-28-2022 09:28 AM
Sometimes it’s also the internal linkage that needs a good cleaning, old lubes/greases either gummed up or ineffective, even binding can occur from the very dry side felt and rubber sill seals at the glass contact.
