broken engine harness connecting 14 pin plug
hello,
I have a 84 Targa with a broken engine harness connecting plugs. Both plugs located on top of the engine are broken with wires now outside the male female connecting boxes. I have not found a relevant diagram in my Bentley book. can you help with the relevant diagram with the fourteen numbered pins with pin #, location and color? Much appreciated. I am afraid to start the engine and fry the DME. The engine is back in the car and ready to fire. THANKS. |
Try reaching out to [mention]timmy2 [/mention] Dennis rebuilds these and sells new cables as well.
thanks I did yesterday and he contacted me. I am waiting for a color chart for the 14 pin box.
Regards. |
Would you share it once you get it? I searched pin assignment for your 14-pin connector in the workshop manual diagrams but found nothing.
Only found pin numbers for injector plug. Only 4 pins are used out of 6. (tu es français ?) |
Quite often the pins just lay in their original position when removed from the plastic holder.
Ok, took one apart.
Male pin out as per numbers on the base: 1. Fat yellow 2. Red 3. Green/Black. 4. Green/Red 5. Green/Yellow 6. Gray/Brown 7. Empty. 8. Brown/Black 9. Green/White. 10. Empty 11. Blue 12. Empty 13. Yellow and yellow/Red 14. Red http://forums.pelicanparts.com/uploa...1672517827.jpg http://forums.pelicanparts.com/uploa...1672517827.jpg |
Thanks Dennis. Always useful to have this kind of info.
| All times are GMT -8. The time now is 04:35 PM. |
