CIS injector leak
Hi,
I'm doing a few health checks on my CIS components to troubleshoot a rough /low dle during cold starts. I checked injector flow, all are evenly matched with good spray pattern and no visible leaks with air flow sensor plate lowered. I left the injectors in dry containers for an hour or so after turning off the fuel pump and found a few drops of fuel in them. Is this normal, or should the injectors seal.perfecly against residual pressure? I wonder if a gradual leak might be contributing to the starting issue Thanks John |
| All times are GMT -8. The time now is 01:17 PM. |
