Dan Morton's Avatar
Rear sway bar
I am looking to find a stock rear sway bar for my 1970 911T. I'm not looking to race the car but just want to put the stock bar back on (other is lost...long story).
What year 911 sway bars would work? I've posted a WTB message in the classified area but no one seems able to come up with an old sway bar....surely with all the upgrading going on out there someone would have one : )
Thanks!
Dan
Old 02-28-2003, 11:19 AM
Stay away from my Member
campbellcj's Avatar
It actually should be fairly easy to find a stock rear bar from a 69-8x car. A lot of the racer & R-Gruppe guys go to bigger bars. Just keep your eyes peeled here, and on Rennlist classifieds as well as ebay.
If all else fails, you can use the 19mm Weltmeister bar for not a ton of money although then you'd likely want a 19mm bar up front to keep the same balance. The ride would degrade somewhat, however, compared to the smaller (15-16mm) bars.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 02-28-2003, 08:37 PM
Early_S_Man's Avatar
Porsche Crest
Dan,
Any '69 thru '76 bar would work ... the '77 models got the links with bolts at both ends.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-28-2003, 09:16 PM
Senior Member
INstallation
I am installing rears this WE. My E did not have factory bars, installed stock fronts this past WE, how do the rears attach? I have home made adapter brackets to go over the torsion tubes, but how do the twisted links attach?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 06-03-2003, 07:40 AM
Porsche Crest
Chris,
Most aftermarket bars use a bolted link arrangement ... rather than the factory ball-stud pin [#11 in the diagram above] that had to be welded in place in the factory retrofit kit.
Warren Hall, Jr.
Old 06-03-2003, 07:48 AM
ttweed's Avatar
You can still use the larger, later bars on an early car with some fairly straightforward modification. See this article by my mechanic. I run a 21mm Carrera bar on my '73 like this.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 06-03-2003, 08:05 AM
Senior Member
So if I don't have the pins from the factory, is there an adapter set that attached the open end of the bars to the car? Are these u-bolt type attachments or do I drill and tap?
Chris
Old 06-03-2003, 08:37 AM
Hilbilly Deluxe
emcon5's Avatar
If you want to try using a later bar, I have a stock SC rear bar I don't need. From that article, it looks fairly simple if you can get the bushings made.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-03-2003, 09:04 AM
Senior Member
I've got rear bars and all the parts, plus the #11 brackets from above, I am just trying to figure out how to mount them if I don't have a the factory pins welded in....
Chris
Old 06-03-2003, 10:12 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
If i were you, i'd use this as an excuse to get some 22mm sways all around .
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-03-2003, 11:33 AM
RETIRED
Joe Bob's Avatar
I have a front and rear bar from an 83.....no hardware.
2012 ML350 3.0 Turbo Diesel
Old 06-03-2003, 12:50 PM
"So if I don't have the pins from the factory, is there an adapter set that attached the open end of the bars to the car? Are these u-bolt type attachments or do I drill and tap?
Chris/Dan,
If you have pre-'77 mounting hardware as pictured and there isn't a ball pin already in the control arm, you must drill a hole in the control arm to accept the ball-pin (#11), then weld in place.
Here are some other options in order of increasing complexity:
- Install a WM sway bar. The drop links attach to the spring plate, not the control arm. However, smallest bar is 19mm. Entirely bolt-on.
- Use the late model sway bars w/modified hardware as described and linked by Tom (TT). However, you'll need to perform the aforementioned drilling/welding modifications to mount to the control arm.
- Upgrade to '74-'77 control arms. These use a ball pin mount for the sway bar. A side benefit is that al arms ('74-'89) are lighter (~13 lbs. ea.) and unsprung weight (~7 lbs. ea.). However, the lower shock mounts are different from '70 shocks which requires a slight mod. and matching year shocks as well...... or
- Upgrade to '77-'89 control arms. These use a threaded drop link hole, then use the late model, threaded drop link hardware or other aftermarket sway bars that use this bolt-on attachment point. Same shock mount issues.
Hope this helps,
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-03-2003, 01:39 PM
Senior Member
Yikes - there goes the plan for a quick install this WE. Dang, was looking forward to some street luge to evaluate the difference. Might it be easier to find some rear control arms with the mounting pins? My factory fronts took me days to painstakingly restore, stripped and coated with Wurth, all new fasteners, looks nice. But if the aftermarket weltmeisters are 19mm and up, the 15mm fronts will be out of whack.
Chris
Old 06-03-2003, 03:58 PM
