What part number for this rubber part?
Hi guys,
I've been looking for a rubber seal located in the ring on the blower motor for a while now but it looks like it might be no longer availiable. If anyone can tell me what partnumber this part is, I would be over the moon. Many thanks, David ![]()
1973 2.4 MFI bone-stock 911T Last edited by D@vid; 03-24-2022 at 12:49 PM.. Reason: adding photo |
1973 2.4 MFI bone-stock 911T |
This is for the fan motor mount, not sure if it's what your looking for. If it's inside the blower, probably not available, and you would have to make one.
901 571 922 00 https://www.pelicanparts.com/More_Info/90157192201.htm?pn=90157192201&bt=Y&fs=0&SVSVSI=5878
Ed 1973.5 T |
Administrator
In diagrams it looks like it may be part of the unit itself..
you may be hunting for an entire blower motor
Hi David, did you ever find it? I'm looking for the same thing!
check out 914rubber dot com , they'd have it if it were available.
As Coblue said:
914Rubber Airbox Motor Seal for 911 and 914 SKU: OEM91157101800S $22.00 |
PCA Member since 1988
Just use your favorite brand of silicone sealer instead.
