Oil in heat exchangers
911 has been sitting for some time now. Lower valve covers leaking oil that has gotten into heat exchangers. When I started car lots or oil smoke coming out of interior vents.
Any idea how I can clean all this oil out? Otherwise The heat exchangers are in good shape. Thanx |
First, close the heat flaps and fan then go for a long drive.
You state “into” rather than “onto”. It’s hard to imagine the HE casing could contain a pool of oil inside. Might be the oil is just on the top and along the manifold, of course the length of time it’s allowed to drip makes the burn off that much longer. Other than taking the HE’s off any flushing them, there’s no other way to clean the interior. The oil will eventually burn off and rather quickly with an extended drive. If leaving the car on extended storage before replacing or re-torque the cover gaskets, a bit of aluminum foil covering the HE’s and funnel those drips away to a boot tray filled with kitty litter. |
I had the same issue. I removed the exhaust and cleaned out best I could with brake cleaner then engine cleaner with water. It might have been better to use engine cleaner and blast it at a car wash. I reinstalled and made sure the flappers into the heat ducts in the car were closed. When properly shut the smoky air won’t go in the car and it will escape at the valve. I drove for awhile and tested the heated air quality. Eventually I was able to have heated air without having to roll down the windows Edit Oil did actually seep into the HE at the joints where the tube goes through to allow access to exhaust studs They are SSI Sent from my iPhone using Tapatalk Last edited by TwoBluPorsches; 12-22-2022 at 09:04 AM.. |
Slow old car
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
I like the way some of you guys say "I took off the heat exchanger"!. This is often a job fraught with difficulty as the studs snap off. It's a job I left to my local garage who have access to heat. Of course I imagine they would come off easily now, but I would just drive the car and let the oil burn off.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
CDN Redneck
I did have the Stromski kit for the studs of which I broke one.
84 Carrera Coupe 3.2L Tea Tray Tail Black on Black |
Be very careful, i had a car almost burn to the ground
If a car stands long without driving, oil can build up in the exchangers through a minor leak And if not really heated up the first drive the oil can catch fire in the exchangers. |
PCA Member since 1988
Some years ago, I also got water into the heat exchangers from parking it out in the rain. After starting it up, the evaporating water fogged the windshield terribly. So, I drilled a couple 1/8' holes in the forward lowest part of the heat exchanger. Bonus: it also lets the oil drain out!
My SC had that problem when I had left it parked for 3 months or so.
Phew, a bit smelly inside the car. But I took it for a long hard drive - with the windows down as you can imagine. Got the exhaust hot from the drive and the smell was gone an hour or two later. |
I had some slow oil leaks that made their way down into my heat exchangers. I traced the leaks to the rocker shafts and eliminated them by installing RSR rocker seals.
With the leaks stopped I then cleaned the heat exchangers by soaking them in a vat of simple green to loosen up the accumulated/cooked on oil, scrubbed the outside with 3m pad, and cleaned out the interior passages as best I could with a hot water pressure washer. The result was no more oil smell when i use the heat. ![]() ![]() ![]() Last edited by rswannabe; 01-05-2023 at 10:14 PM.. |
I am thinking of adding the Rocker lock sets and RSR seals also while I'm in there doing the valve gaps. But, if I have to remove the engine, I'll plan for a future date. |
