head stud nut size
Hi,
i'm preparing for a valve job and i d like to also check head studs are torqued correctly.
can anyone please tell wich allen size i need?
is there any other specific tool you use to do this job?
Engine is a 1973T
Old 01-09-2023, 06:04 AM
I believe It’s a torx head. T50 or T55 on my 1972
Old 01-09-2023, 09:51 AM
It’s a 10mm allen nut.
Old 01-09-2023, 09:57 AM
I believe you are correct.
Huh, I found my torx and my long 10mm allen socket.
It’s been 30 years since I rebuilt my 2.4L.
Trying to recall why I have the big torx.
Old 01-09-2023, 10:30 AM
Big torx is probably for your door striker.
Old 01-09-2023, 10:38 AM
Originally Posted by fizeus View Post
Hi,
Engine is a 1973T
I’m assuming you mean valve adjustment? Bent feeler gauge.
Old 01-09-2023, 10:44 AM
Thank you all for the help.
Just bought a 10 mm Allen socket with different extensions ...
Dpmulvan, yes I mean valve adjustment and I already have a bent feeler gauge (p213b).
I only had to bend it at 90° to be able to slide it between the valve stem and the adjustment screw.
F.
911 2.4T from 1973 Gemini Metallic Blue
Old 01-09-2023, 03:04 PM
Fizeus:
have you herd of a new technique to adjust the valves on the 911 engine > snapgaps
https://www.youtube.com/watch?v=MsTgFlq_czI
I'm going to use it on my next valve adjustment -
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 01-09-2023, 10:43 PM
Yes, I've read a lot o review about this tool and it seems very useful ... but I think I prefer the old method.
I 've done the previous valve adjustment with the help of the famous "Kirk engine valve lash tool" and now I just want to check if gaps are still in specs or not (strangely my engine has developed a clackety-clack sound so I am hoping it's just a valve out of specs more than a worn valve guide)
Let's keep finger crossed
Old 01-10-2023, 12:52 AM
Your clackety clack is probably chain tensioner related.
Old 01-10-2023, 04:49 AM
