What is normal pad under carpet 930
I have an '88 930 and am doing some winter clean up and have the seats out. What is the normal pad that came from the factory in these cars? It had something, right?
My car seems to just have carpet laid on the floor - no pad or anything. I'd like to put something back whether it's carpet or some of the noise / heat barrier padding folks use.
Thoughts / ideas?
Old 01-20-2023, 01:23 PM
cycling has-been
bkreigsr's Avatar
carpeted pads directly on the painted floor sounds about right
Old 01-21-2023, 09:10 AM
ADDvanced's Avatar
Leaves, brake fluid from a leaky MS, cigarette butts, random fasteners, and business cards from the 70s. That's what's been under mine, at least.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 01-21-2023, 02:57 PM
McDonalds fries?
Old 01-22-2023, 06:09 AM
Senior Member
Originally Posted by Eljimberino View Post
McDonalds fries?
Save them they work great as shims.
Old 01-22-2023, 06:17 AM
Your car should have a 2-2.5 mm (now hard) tape like insulator on the floor surface. It tends to harden and crack/chip off on our older cars. See pix below for a detailed look. I added Dynamat to a 75 - 80% standard, largely in thee recessed square areas. Works well, not much weight gain. Brown substance is adhesive in pix.
'86 Porsche 911 M491 Cab. Guards Red/Black. Sold '93
'86 Porsche 911 M491 Cab. Iris Blau Metallic // Turbo-Look Registry #4200
Old 01-22-2023, 08:13 AM
After Dynamat
After cleaning, new carpet kit (Lakewell) before seats...
Old 01-22-2023, 10:11 AM
cycling has-been
bkreigsr's Avatar
sorry, but I don't see any factory tape in this pic. I do see the factory stampings for rigidity in the floor.
Old 01-22-2023, 01:41 PM
The black is the "tape" or adhesive mat used as insulation/sound deadening on the tubs. It is very rigid with time and brittle. Note the wear at the heel point under brake/accelerator area.
Old 01-22-2023, 02:29 PM
Thanks, yup, that is pretty much what mine looks like. It was just surprising to me that there wasn't much / anything there. I'll probably add Dynamat or similar
Old 01-23-2023, 05:43 PM
cycling has-been
bkreigsr's Avatar
Here's a popular replacement from a reliable supplier.
Note that the piece is bare metal, and the indentations are stamped.
Old 01-24-2023, 09:49 AM
cycling has-been
bkreigsr's Avatar
Old 01-24-2023, 09:54 AM
ADDvanced's Avatar
I can't imagine adding sound deadening will do much on the floor, it already has a ton of geometry/is fairly stiff, plus it has that mastic black pad glued to it; I just can't see it resonating like door panels or other large flat smooth panels. I'd leave it.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 01-24-2023, 11:11 AM
On the 964 there was rigid foam on the floors.
I have never liked anything stuck on the floor in addition to the factory tar like rigid pads. If you have a water leak it will sit under the insulation and rust or at the very least, get moldy.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-24-2023, 12:13 PM
I am used to the old 911’s that have basically nothing under the carpet as discussed here. However, when I was working on my 993 a number of years ago I was amazed to find the factory insulation to be about 1”-1.5” thick under the carpet. It was mostly foam with some mass loaded vinyl if I remember correctly. There is a reason those cars are a lot quieter and more refined. I really doubt Porsche would have added that sound insulation if it didn’t do anything.
Old 01-24-2023, 05:33 PM
Tags
carpet pad
