Oil? in my tunnel
Waiting for my shift coupler and I noticed that there is fluid in my tunnel. Any ideas on where i should start looking or is this normal. I wouldnt think it would be.
Steve "grimlin" 76 Targa Gruppe B #65 "On the wings of my brothers all things will come to pass" |
Senior Member
Probably dribbling out of the shift rod seal on your tranny. It is possible to replace this while the tranny is still in the car, but it's tricky. The seal is located where the shift rod enters the point of the tranny that pokes into the tunnel.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Well then thats where i will start
thanks
Slumlord
It's not brake fluid?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
RETIRED
Could also be migrating up the speedo cable from the trans angle drive.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
hmmmmmmmm
would i have to have a mechanical speedo for that to happen?
As others have said, it is the input shaft seal. If anyone has changed this seal on a 911 with the trans in the car I would be interested to hear how it went. It is difficult enough to remove the seal with the trans out of the car.
RETIRED
Mechanical....yes. You did not mention the year of the car....
Paul, I did my G50 shifter shaft seal with the tranny in situ. PITA, but I think it is easier than the 915. Here is the tech article about how to do it.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne Last edited by Don Plumley; 06-03-2003 at 10:43 AM.. |
It doesnt sound that hard of a project. I'll check things out when i get home tonight. thanks everyone
This is no help to you but I thought I'd share what I found in my 73.
The car leaked like a sieve everywhere plus the rubber boots around the shift coupler were totally gone when I got it. The cas was from Wyoming and had obviously been on a lot of dirt roads (a lot of times too). The tunnel was full of an oily dirt/sand mix. My daughter and I spent about half an hour one Saturday using plastic spoons and removed about 2 pounds worth of it. Enjoy your project, it could have been worse.
Fritz 1987 944S 1973 911E |
I did it with my 901 in place using the Pelican procedure. Yup - it was a PITA. But after about 30 - 40 minutes at hacking the old seal out, putting the new one is was a piece of cake.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 06-03-2003 at 12:42 PM.. |
Didnt get a chance to look at it last night. Have my girls for the summer and forgot how much time they require. And its great!!!!!!!!!!!
