Barrpete's Avatar
Footwell blower fuse upgrade
I'm replacing my footwell blowers and am planning to add a fuse. My question is can a 20A fuse be added at some point 'upstream' rather than installing a 10 A fuse on each blower behind the kick panel. And if so where? Seems like it would be a lot easier to check the fuse without having to remove the kick panels.
I did a search and found lots of references and recommendations to add the fuse but no descriptions on how others actually did it. Thanks.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 02-04-2008, 07:43 AM
Nope, That's like fusing a 20 amp circuit in your house with just the main 200 amp breaker. The big breaker won't protect until way after the damage has been done. The 10 amp fuse doesn't need to be checked. When the blower stops blowing that will be the indication that the fuse blew and saved your wiring and maybe your car. There are nice sealed inline units that take a more modern fuse.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 02-04-2008, 06:11 PM
Barrpete's Avatar
Thanks Ron, that's exactly what I needed to know. And it makes perfect sense now. D'oh!
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 02-05-2008, 07:35 AM
Make Bruins Great Again
Por_sha911's Avatar
Also, if you are blowing a fuse you need to take the kick panel off anyway to find out why.
Joe
Old 02-05-2008, 07:15 PM
Barrpete's Avatar
You are right, of course. I was just thinking that since there are multiple reasons that the blowers might not operate, the troubleshooting process would be a little easier if the fuse was visible. A good fuse + non working blowers would indicate the problem was likely somewhere else.
Donations gladly accepted at www.electricallychallenged.org
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 02-06-2008, 06:41 AM
KatoKato's Avatar
Originally Posted by Barrpete View Post
...I'm replacing my footwell blowers and am planning to add a fuse. My question is can a 20A fuse be added at some point 'upstream' rather than installing a 10 A fuse on each blower behind the kick panel. And if so where? ...
I'm considering adding fuses as well.
Isn't it possible to insert a fuse somewhere in the trunk?
Old 07-12-2008, 04:36 AM
Por_sha911's Avatar
It is possible but having the fuse close to the blower is the best thing. You can buy in-line fuse receptacles to be spliced into your power line to the blower.
Joe
Old 07-12-2008, 09:09 AM
Barrpete's Avatar
I don't think you can without running a lot of extra wire. And as Ron said each blower needs its own 10A fuse. I just ended up splicing a mini blade type fuse holder from Autozone right at each blower. Pretty easy really.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 07-12-2008, 09:45 AM
KatoKato's Avatar
Ok. Thanks.
Do you know of any threads that have pix of the procedure ...?
Old 07-12-2008, 01:18 PM
Barrpete's Avatar
I looked when I did the install & couldn't find any. It really is pretty easy though. Just remove the kick panels & unplug the harness from the fan. The wires are wrapped in a plastic sleeve that you'll need to cut back far enough to have room for the splice. There should be a brown wire which is the ground & a green with white stripe that is the hot. Splice the fuse holder into the green/white wire, plug it back into the blower motor and you're done.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 07-12-2008, 04:57 PM
KatoKato's Avatar
This needs to be done with both blowers? (10A fuse X 2)
Old 07-17-2008, 10:47 AM
Barrpete's Avatar
Yup. Each blower needs its own 10A fuse.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 07-17-2008, 11:59 AM
Wavey's Avatar
Each footwell blower already has it's own 10 amp fuse built into the factory wiring harness. Are you trying to retrofit these to a car that doesn't have them?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 07-17-2008, 12:08 PM
Barrpete's Avatar
I think the '87 was the first year that had fuses on the footwell blowers. My 86 for sure did not.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 07-17-2008, 12:32 PM
Wavey's Avatar
Got it. My '88 has them. Bentley shows them for all Carreras 84-89, but then Bentley is known for the inacuracies here and there.
Old 07-17-2008, 12:39 PM
KatoKato's Avatar
Hey Barrpete - Finally went out today and purchased fusues/holders for the upgrade.
Very interesting when I checked my Bentley manual Re: footwell blower - in the picture there is a 10A ATO fuse holder visible?!?
Must've had the upgrade performed?
Old 08-13-2008, 09:27 AM
scarceller's Avatar
If one or both footwell blowers short out you will blow one of the 2 fuses shown in RED in the schematic below. If you are in speed #3 (hi speed) you will blow the fuse on the left. If in speed #1 or Speed #2 (low or medium speed) you will blow the fuse on the right.
Trouble is that those 2 fuses are way down stream from the blowers and a shorted blower could compromise other components like the 'Heat Controller' (low and med speed) or the 'Aux Blower Relay' (hi speed). So it would not be a bad idea to place inline fuses right at each blower motor. Never gave this to much thought but I like the idea.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-13-2008, 10:12 AM
Barrpete's Avatar
Did you check your FW blowers directly? Or just the Bentley? The pic in the Bentley could be from a later year Carrera.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 08-13-2008, 10:54 AM
KatoKato's Avatar
Ok ... I removed the passenger side kickplate and what I found was a fuse holder already spliced into the white/green striped wire:
A couple of questions:
1) Is this the correct wire?
2) There is no fuse in place...and the blower has always worked. At least I think it does. What gives here?
Old 08-13-2008, 10:57 AM
KatoKato's Avatar
See pic above:
Here's what's in Bentley:
Old 08-13-2008, 10:59 AM
