Speedo and ODO don’t work
Sorry as I know my question is kind of vague without further information.
I haven’t been under the car yet to check that cables are connected to the transmission (and that’s all I’m hoping my issue is). But basically I know the common ODO failure information with the gear in the gauge. But the speedo not working just has me scratching my head a bit. The car is a 77’ 911, or for sure has an electronic speedo/odo as I’ve pulled the gauge from the dash and expected it was the mechanical unit and mechanical problems, but it’s electronic lol.
Outside of getting under the car to check the wire are there any other ideas?
Old 10-15-2023, 10:53 PM
PCA Member since 1988
Loose or pulled off ground wire? By poking around in the dash, you might have knocked it loose from the gauge.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-16-2023, 12:41 AM
Don’t overthink it just yet.
1. Pop the gauge out and reseat the connectors
2. failing that, check for voltage on the +12V per the diagram below:
(I stole this from someone else’s post and can’t remember who to credit. It was super helpful when reinstalling my gauge after North Hollywood fixed the odo gear)
Old 10-16-2023, 05:30 AM
Old 10-16-2023, 05:35 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What year? I don’t think my speedo still worked when the odo gear failed.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 10-16-2023, 03:24 PM
Speedo on my ‘78 SC worked fine when the odo failed, FWIW.
Old 10-16-2023, 04:55 PM
To clarify, the Speedo/ ODO not working isn’t because of me pulling the gauge from the dash… neither have worked for years and years, I simply pulled the gauge from the dash for visual inspection and to see if it was mechanical or electronic.
Thanks for everyone’s tips so far!
Old 10-16-2023, 05:04 PM
The cad is a 77’ 911 (Coupe), it’s a ROW car straight from Germany so technically it’s not an “S” (like that matters though lol).
I don’t know what a kilometer is anyways so not sure why I even care if it works or not hahaha.
Old 10-16-2023, 05:06 PM
Where are you located? If you have a multimeter, I would check to make sure you have power and good ground to the speedometer. If that checks out then you can do a quick test by connecting a wire to the speedometer, in place of the wire coming from the sender, and just quickly tap it on and off ground and the speedometer needle should bounce.
If you run out of ideas and you're in the US, I'd be happy to test the speedometer for you.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 10-16-2023, 09:41 PM
Thanks jbell, ya I’m in the us (Minnesota). I have a multi meter and I’ll give that a test this week when I’m working on the car again.
Old 10-17-2023, 02:23 PM
Originally Posted by silverlock View Post
Thanks for this pic!
My Speedo/ Odo is not plugged in like in this picture. I guess maybe my dad monkeyed with it 30 years ago and didn’t plug it back in properly, that’s all I can think of anyways.
Now I just hope I can move the two sensor plugs down 1 each and it’s that easy. That’s what’s different about mine from the pic.
Old 10-22-2023, 07:08 PM
Here’s how my wiring looks (again I have NOT touched any wires or unplugged anything).
https://imgur.com/a/VFpWqJG
(Haven’t figured out how to is photos directly from my phone easily on the forum yet lol)
Oops haha, I think I figured it out (the files are IN the computer)
Old 10-22-2023, 07:18 PM
Old 10-22-2023, 07:20 PM
Remove the 2 wires from the connector I circled and move them to the ground connector on the end.
Old 10-22-2023, 08:25 PM
Thanks! I already did that last night. Now to check that it works after that one of these nights soon, I don’t have brakes on the car atm so I’m thinking I’ll just put into gear on jack stands (even though that sounds like a bad idea to me lol). Otherwise I don’t plan to have the car back in the road until next spring but I’m dying to find out if it was just that simple.
Bad idea to run the car on jack stands with the rears in the air (even if only in gear at about 5mph to verify the speedo now works)?
Thanks for everyone’s help so far!
Old 10-23-2023, 01:35 PM
