Another ventilation/electrical question
My cabin heater fan switch only works on position "2"- I removed the switch assembly and both of the cam switches work both mechanically and electrically. The light in the switch seems to dim in position 3. Is there a resistor pack that this switch feeds, and where? Any other thoughts?
I don't know which car you're talking about, but there's a resistor pack in a little cubby below the passenger-side floorboard on the Carreras. You may have to remove an access cover on the firewall to see it (once you have removed the floorboard).
993 |
If that's correct, I can rip it out...
993 |
Yeah the one under the pass floorboard is for the evap motor, I believe.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
The fresh air motor also has a resistor built in it, but you will have to remove it to get at it.
Steve "A Porsche does more then just go fast in a straight line"
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
