Porsche Crest Loose wire, A/C clutch
P-car people, I have a loose wire under the passenger seat with a big plug on the end. Does anyone know what it's for? It has a bundle brown,red,black wires covered by sleeve and it looks like a relay on the end but I'm not sure. Heated seats maybe? Also how hard to replace a/c clutch, mine is wobbly. TIA
clovis911
01 996 Cab
Old 06-05-2003, 10:59 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Might be for power seats. And depending on which ac you have, i have an extra york laying around.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-05-2003, 11:08 AM
scottb's Avatar
Are you sure the clutch is the problem? Sounds like the bearings in the compressor may be shot. Do you have what looks like a dirty spray up under the rear decklid, near the compressor? If so, the compressor seal is shot and it's spraying compressor oil on to the decklid.
1984 Targa
Old 06-05-2003, 12:08 PM
The unit is supposedly rebuilt, It never beat the Texas sun however, I sweated it out last year, then started getting a vibration in the car about 3 months ago and the outer pulley was wobbly, so I cut the belt till I could regroup. Summer is back!
PS. Thanks for tip on the DME, since I replaced it no cut-offs!
clovis911
01 996 Cab
Old 06-05-2003, 12:20 PM
scottb's Avatar
Take a look up under your decklid, near the compressor. I'm willing to bet you'll see oil sprayed up there. If so, then the seals are shot on the compressor and it will have to be rebuilt (again). There's a Pelican tech article on rebuilding your own compressor, if you're so inclined. If you have to buy a rebuilt, Compressors International in Van Nuys, California has pretty good prices.
Porsche a/c is mediocre, at best, so don't plan on being too cool during a Texas summer!
I'm glad the DME relay worked out.
1984 Targa
Old 06-05-2003, 12:33 PM
