-   -   Erratic idle - locked gears - bad crank position sensor? (http://forums.pelicanparts.com/porsche-911-technical-forum/1133540-erratic-idle-locked-gears-bad-crank-position-sensor.html)
Ken.e 01-23-2023 07:55 PM
Recently drove my 74 911 to my fabricators shop for some metal work - car was running perfectly. Picked it up and immediately noticed that the idle was off. Sits at 2k, moves up and sticks/revs higher as the throttle is depressed. In addition, the 915 won't go into any of the gears while the car is on, but gears go in fine when the car is off. In searching around this combo sounds like symptoms of a crank position sensor that has jumped ship. My car has a 3.6 964 swap with a Patrick Motorsports cabin harness that has a built-in diagnostic port. I have tried three different scanners and cannot get the any readings. My next move is to pull and test the crank sensor with a multimeter. Anyone know the signal reference this sensor needs to put out? I would appreciate any useful advice.
Thanks in advance!!
ed mayo 01-23-2023 07:57 PM
Was any welding done on car?
Ken.e 01-23-2023 08:51 PM
Yes but the battery was disconnected.
rswannabe 01-23-2023 09:59 PM
Not going into gear while running sounds like the clutch is out if adjustment. High idle could be sticking throttle linkage. What work was done on the car? Anything around the pedal cluster or trans tunnel?
Ken.e 01-24-2023 12:07 AM
Rear RS fender flares were welded on. Clutch adjustment was fine when the car was driven over and everything shifts fine when the car is off. Only gate issues are when the car is on.
Ken.e 01-25-2023 05:35 PM
Anyone with a similar experience?
stownsen914 01-26-2023 05:42 AM
Have you shared your observations with the shop? Clearly something happened while your car was there.
I'd start by troubleshooting the symptoms you are seeing. For the high idle, is the linkage on the engine returning to the idle position? That's easy to check, and can rule out a linkage/cable issue.
Re: the trans not going into gear while the engine is running, check the clutch adjustment as suggested as that's also easy. Once confirmed good, try again. You can hold the clutch in for a few seconds to let things spin down (from the high idle). If nothing else is wrong, it should go into gear easily.
Ken.e 01-26-2023 10:17 AM
Thanks for your input. While that all makes sense, it seems odd to me that both the throttle cable and the clutch adjustment would simultaneously go out of adjustment while the vehicle sat for two weeks. I just adjusted the clutch cable less than 500 miles ago. I did share my observations with the fabricator, he said the vehicle did not move while at his shop. As far as the idle, it sits at 2k when I start the car and if I throttle it, the idle moves higher and higher. The crank angle sensor came to mind since a failed unit can cause erratic idle and locked gears from what I read. I plan to pull it and test it this weekend when I have spare time.
targa72e 01-26-2023 12:13 PM
Crank sensor will do nothing to keep the transmission from going into gear unless it broke off and got wedged in the clutch. The fact that the idle goes higher and higher if given throttle sounds like sticking linkage. I wonder if they jacked the car up (maybe to take tires and wheels off) and they jacked from the center on the engine/transmission and bent/ crushed something.
john
stownsen914 01-26-2023 01:34 PM
@Ken.e - don't assume they simultaneously went out of adjustment. Unfortunately we have no idea what the shop did to your car. This could easily be two problems that happened to come to your attention when you picked up the car.
Ken.e 01-26-2023 02:26 PM
Valid points. The fab guy said he used the supplied jack pads but to stownsen914's point, we don't know what could have happened while the car was there. I will go over the throttle linkage and clutch adjustment this weekend. Thanks guys http://forums.pelicanparts.com/suppo...s/beerchug.gif
Ken.e 01-27-2023 09:16 AM
Update - disconnected the throttle cable to see how the motor would run per advice from a friend. Engine idled perfectly, connected the cable back on and everything seems fine now. There must've been a hang up somewhere. I then checked the clutch cable, and it did need a minor adjustment to meet 1mm spacing. I adjusted it and still cannot access any gears. I loosened it a bit more and still no access. Will continue to do research but a bit stumped here. I would appreciate any useful advice.
stownsen914 01-27-2023 01:57 PM
Progress is good ...
Re: gear selection still being off - the symptom is a bit odd, but I'd do a visual check of the linkage for slop at connection points or bushings, restricted movement, or anything just looking off. And check the engine mounts - if one is failing, droopy, or loose, it could make for unhappy shifting.
PeteKz 01-28-2023 05:42 PM
Check the clutch release lever on the bottom of the trans. When a jack is used under the engine, if it isn't carefully located, the lifting block or pad will bend that arm. Then the clutch cable does not make a straight line to the arm. BTDT. Look for bending or damage to the throttle linkage under there too.
Ken.e 01-30-2023 12:43 PM
Update - I went over the linkage over the weekend, everything appears fine. I also made some adjustments to my Wevo shifter and coupler which did not help much. Adjusted the clutch cable, that did nothing. In racking my brain, I thought that perhaps the trans is low on gear oil. There is some oil under the trans which leads me to believe there may be a slow leak. I filled the trans when I did the 3.6 swap back in 2019. Thinking 3.5 years - slow leak - likely needs oil. I have been meaning to switch from Swepco to Kendall anyway so will do that this coming weekend. @PeteKz - good call but the guy that did the work on my car knew to use the jack pads. My car is lowered so not sure that you could even get a jack under there.
pampadori 01-30-2023 01:22 PM
can you get the transmission to change gears while the engine is not running?
If you can while off, but can't while running i'd look at clutch not releasing for some reason.
If you can't change gears with the engine off either, i'd say you might want to remove the inspection plate to have a look at things while a helper attempts to change the cears (engine off of course sind all the trans fluid will be drained.)
Ken.e 01-30-2023 05:48 PM
I am able to shift the transmission normally while the car is off. Not going into gears while the car is on. I did a test earlier per a friend's recommendation; put the trans into all gears with the car OFF then turned the ignition key and the car jolted in every gear. This tells me the clutch is doing its job and the issue must be in the clutch cable somewhere.
targa80 01-31-2023 04:57 AM
Over the years I have had the issue of not being able to shift into gear after starting the engine . The car would grind in any gear I tried. On level ground I would shut off engine, press and hold clutch down, shift into 1st. While clutch is pressed down start engine and car would roll. The clutch and clutch plate are stuck together. The way I would fix the issue of the stuck clutch I would put the car into first and get the car moving and slam on the brakes. Granted, the engine will stall but it will also free the clutch. This has happened to me about 5 times over the past 19 years. Why it happens ???? Also, my clutch is all adjusted properly and shifting is normal when unstuck.
stownsen914 01-31-2023 01:19 PM
targa80 makes a good point. After sitting for some time, the clutch disk can fuse itself to the pressure plate and/or flywheel. Condensation followed by rust perhaps? Never happened to me in a Porsche, but it did happen once in a non-Porsche that sat for a few months outside. To see if this is your issue, with engine off, push the clutch in while in gear and see if the car can be pushed. If it doesn't move, your clutch isn't releasing properly and could be fused.
Ken.e 01-31-2023 09:50 PM
Hey guys - good call but tried this and the car moves fine while in gear with the clutch pedal in. I am going to recheck clutch linkage over the weekend.
mikedsilva 02-01-2023 04:22 AM
I always use a rope/strap tied to the steering wheel, to hold the clutch pedal fully up, while adjusting the cable...
Ken.e 02-06-2023 04:58 PM
Interesting. Thanks for the info.
Spetrow 02-06-2023 05:42 PM
If after correct clutch adjustment, you get gears with engine off and no gears with engine running, it could be a cracked or bent clutch release fork.
Ken.e 02-08-2023 06:46 PM
Update - I swapped the trans fluid to Kendall 80/90 from Swepco, had been meaning to anyway. Also took mikedsilva’s recommendation and ratchet strapped the clutch pedal all the way up, then re-adjusted the clutch lever bolt. This was helpful as I feel like I got a better adjustment. When I fired the car up, it was still hesitant to go into gears but was not as harsh as before. I took the car for a drive since I was able to somewhat get into gears. In going for a drive the car instantly shifts normal, zero issues. The gearing issue seems to only be while the car is sitting idle. I will continue to research but this seems odd to me. I would appreciate any useful feedback. Thanks guys.
targa80 02-09-2023 05:07 AM
If after checking and adjusting your clutch system you cannot engage into any gear while at a stop with engine running and clutch pedal to the floor then I say again, you have a stuck clutch to clutch plate. Every time I have had this issue when I first try to start the car after being parked in the garage for sometime. Sometimes I do not take the car out for several weeks. When it happens, I would turn the engine off, then I would engage reverse gear, start the engine and drive out of the garage. Shifting gears while moving is not an issue with my car. When I needed to come to a stop I would down shift into second and leave it there with the clutch depressed, then release the clutch and start driving from second gear. Trying to shift into first before stopping was to difficult. This technique is only used until I am somewhere where I can force the clutch to free itself. I usually use reverse gear to free the clutch as noted in my previous post. Why this happens on my car still alludes me, all I know is that once in a while it happens . I have previously posted this issue years ago on this forum with no reply’s providing a meaningful answer to the issue. I have no desires to pull the engine to rebuild the clutch since I only have 20k on the previous rebuild. Granted that was over 20 years ago. I am sure if my Porsche was my daily driver now like it was in the 1990’s I would not have this issue.
Ken.e 02-09-2023 09:20 AM
Interesting. I guess this makes sense especially in the cold winter weather. Now that I think back, this has happened to me in the past. At the time, I had a Rennshift shifter, I did some adjustments to it and the problem went away. My clutch kit (Centerforce) has less than 3k miles. Odd issue.
Ken.e 02-09-2023 12:19 PM
Pat - tried your method of slamming on the brakes while the car is rolling in 1st gear. This immediately solved the problem then it went back to doing it again (can't get into gears while car is on and not moving). If your theory is correct, I supposed I may have sticky clutch plate.
PeteKz 02-09-2023 01:44 PM
Hate to bring up expen$ive possibilities, but also could be the crank pilot bearing beginning to seize. I would not continue driving it until you figure out the problem. Start by measuring the throw of the clutch release arm when you step on the pedal. I don't know what the spec is, but if it's moving a full stroke and still not releasing then I'm afraid you will have to drop the transmission and inspect the clutch and pilot bearing.
Ken.e 02-10-2023 03:56 PM
Fun times. This weekend I will measure the clutch cable throw. Per my review, it should be 25mm. I will also check the clutch clevis and pin connections. If that all checks out, I will likely have to drop the motor later in the year and inspect the clutch, pilot bearing and transmission shaft seals. Motor has only been in for less than 3k miles :)
