-   -   915 reverse gear install direction (http://forums.pelicanparts.com/porsche-911-technical-forum/1133685-915-reverse-gear-install-direction.html)
thetorch 01-26-2023 06:41 AM
915 reverse gear install direction: markings out or markings towards the gearbox?
On disassembly my markings were facing inwards, but my Bentley says markings should face outwards.
Maybe it doesn't matter since it's reverse, or maybe the prior builder knew something I don't.
http://forums.pelicanparts.com/uploa...1674747673.jpg
gled49 01-26-2023 07:13 AM
If your concerned, install the reverse idler gears and look at the offset as witnessed by wear on small gear, and install that way.
kevingross 01-26-2023 09:26 AM
Numbers face outward. Perhaps less critical for reverse since it doesn't get used to much and noisiness is less of a concern.
thetorch 01-26-2023 10:16 AM
Thanks. Makes sense.
icarp 01-26-2023 11:16 AM
numbers out and the wear pattern on the pic shows the gear is in backwards
thetorch 01-26-2023 03:57 PM
Ian,
curious if the wear pattern on the gear teeth or on the outside face is the tell. Trying to learn as I go...
thx
icarp 01-26-2023 05:01 PM
The tooth at 10 oclock has a wear bar at the inner edge of the tooth , a dark line
If you flip the gear the dark line will be on the nut side .
Then put the other shaft in and all the bearings ans sleeve and you can see the tooth match up where the dark edge is just off the other gear .
Hope this helps
kevingross 01-28-2023 01:45 PM
Hope this helps
That's not wear. It's an area of the tooth that does not make contact with its mate, has not been lapped and sees no practical wear. The same is true for the opposing area ("nut side"). Cheers,
Hotshot 01-28-2023 06:38 PM
When I undid my first 915 box I worked on..
http://forums.pelicanparts.com/uploa...1674963325.jpg
icarp 01-29-2023 04:43 AM
That is exactly what I am saying , lapped or any contact pattern
The visual que is what I am pointing out .
Same stuff different words
Ian
thetorch 01-29-2023 06:43 AM
I'll bite: The broken idler gear teeth? Feel like I am failing some eye test...
Hotshot 01-29-2023 06:51 AM
Good eye. Ya apart from all the syncros being shot, dog teeth shot, case bores spinning, the idler has a tooth chipped. Lol. That was staying put.
