seafood10's Avatar
Rear Bumper Bellow Clip Help
I'm replacing my rear bumper bellows and just noticed that there is a clip required and I'm not sure where it goes or how to install it.
There is one required per side.
The part number is 911-505-376-00 and here is the part on out host's site:
https://www.pelicanparts.com/More_Info/91150537600.htm?pn=911-505-376-00-OEM
Any help is always appreciate and TIA!
84 911 Cab
87 911 Targa
88 930 Cab M505 Slant Nose
62 356B Gone
Old 02-07-2023, 09:27 AM
It fits vertically inside the bellow and I suppose is designed to support the bellow and prevent the shape collapsing over time. They can be a bugger to push into place
Old 02-07-2023, 11:14 AM
seafood10's Avatar
Thanks! I can see where it goes now, any tricks to getting it in?
84 911 Cab
87 911 Targa
62 356B Gone
Old 02-07-2023, 12:05 PM
It’s not so easy to describe but here goes. Hold the bellow in a vice or similar clamping arrangement by its top flange or get a friend with strong hands to hold it on a bench. Insert one end of the clip into its mounting hole. Using a pair of pliers with good grips take a very firm hold on the clip bend/manoeuvre it into place in the other mounting hole. It’s not easy as the clips are quite strong. Good luck
Old 02-07-2023, 12:46 PM
Original Owner
tsuter's Avatar
Insert it into the bellows while your entire bumper assembly is on the ground and the bellows is not pinched between the lower fender skirt and the bottom of the quarter panel/taillight assembly area.
Easy to do here as you can spread the bellows.
Difficult to do when its all on the car and you can't spread the bellows.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 02-07-2023, 01:21 PM
seafood10's Avatar
Awesome help!! With your help I was able to get the old one installed in my new bellow and am going to will call a new clip from Pelican tomorrow for the other side.
Thanks again for taking the time to help!!
84 911 Cab
87 911 Targa
62 356B Gone
Old 02-07-2023, 06:35 PM
