Analog Air Cooled
Front end redo, Cerakote and Yellow Clad
Every winter I do something on my car. This season it’s the front end.
Years of road use, it was time to change out all the rubber, blast everything, re cerakote, and then the issue bolts came up. Buying the exact bolts is a pain in the A$$, plus I like to restore vs repair. So I learned to yellow plate. It’s pretty easy as long as you have all the right equipment and Prep Prep Prep. Iron oxcide blasting for Cerakote and glass beed for the bolts. After all that work, they are getting a clear coat of cerakote to stay forever shiny. The pic with the roll bar you can see the air dry (more heat resistance) vs the Oven dry ( Insane scratch and durability) but only good on cooler applications. You ad a catalyst to the air dry to make it oven dry.. ![]() ![]() ![]() ![]() ![]()
86 Targa 91 964 13 6 SPD Cayenne Last edited by Hotshot; 01-28-2023 at 08:03 PM.. |
Analog Air Cooled
86 Targa 91 964 13 6 SPD Cayenne |
Uncertifiable!!!
Very nice. Thanks for sharing.
The yellow coating is particularly interesting as yellow zinc counting is being fazed out here in Canada. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Love the idea of an every winter major project. And your refinished parts look amazing. I’d like to learn more about the various diy coating methods/ options. Nice work!! Inspirational & motivating. Thanks for sharing.
Analog Air Cooled
This is the Casswell system. Check it out. It’s awesome. |
Uncertifiable!!!
Would appreciate a PM with a link to the WhatsApp, thanks. Johan
Did you also do the blasting yourself?
