where is TDC with A/C pulley?
On my 86 I can see the 3 120° markings on the engine pulley, however, the so called Z1 mark is hidden by the AC pulley. Is there another way to determine the correct position.
Is it correct that I see an advance ignition mark at the yellow arrow, and if so that this means the red marking is the Z1? Is it true then that if I am at Z1 AND if the rotor of the distributor points at the yellow cylinder #1 marking, that then I am at TDC for cylinder 1? http://forums.pelicanparts.com/uploa...1675092655.jpg http://forums.pelicanparts.com/uploa...1675092655.jpg |
| All times are GMT -8. The time now is 02:00 AM. |
