-   -   Is it possible to separate the rear parcel shelf? (http://forums.pelicanparts.com/porsche-911-technical-forum/1133987-possible-separate-rear-parcel-shelf.html)
FrontGarage911 01-31-2023 10:16 AM
I have two parcel shelves that I'd like to swap bottom panels. My question is, is it possible to separate either panels without damaging them?
https://i.imgur.com/C0loPNRl.jpg
I snagged this photo from the classifieds.
myamoto1 01-31-2023 10:53 AM
Yes. I did this on a 993 parcel shelf. I'm not sure how the older shelf is attached, but the 993 is mostly staples and a little adhesive.
FrontGarage911 01-31-2023 02:04 PM
How do you staple it back together?
Thanks for the help!
seafeye 01-31-2023 02:54 PM
If you bend up the staples you can separate the parts. It’s 3 pieces. The vinyl is wrapped around. Kinda hard to explain but once you bend the staples up you’ll easily see how it comes apart. Two different size staples will be required to assemble.
