Broken rear bumper extension bracket stud
One of the studs that the rear bumper extension bracket mounts to is broken.
I was thinking of grinding the remaining stud flush and then drilling it out to insert a rivnut. Thoughts? |
It looks like the material may be thick enough that you can thread the hole after you drill through the middle of it. Otherwise I would oit a bolt through the hole from the back side and tack weld it in place.
| All times are GMT -8. The time now is 05:19 AM. |
