davis911s's Avatar
Clutch measurment for replacement
I have my engine and trans out of car. it has been off the road for almost 20 years. I had my clutch replaced a few years beofre I stopped driving it and it would only have a few 1000kms on it , but it is older. I am debating putting a new clutch in now, or not. What I would like to know is what is the thickness of a new clutch vs measurement on a clutch thickness when it should be replaced. Thanks in advance
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 02-16-2023, 04:07 AM
I used a 73T ALU pressure plate that had been in storage for 25 years in my 2.7MFI build, with new disc and release bearing, works perfectly. If yours has an ALU cover, you probably can’t buy a better one today. Clean it up real good.
Old 02-16-2023, 07:04 AM
davis911s's Avatar
Thank you. Good point. DO you know the wear measurements for the disk?
Shawn
77 Targa with 2.7
Old 02-17-2023, 06:50 AM
Assuming we’re talking about a 77 2.7: 8.1 +- 0.3, .06 runout.
Old 02-17-2023, 08:05 AM
if its only done a few thousand ks it is basically brand new.
Old 02-17-2023, 05:11 PM
PCA Member since 1988
Ditto. Don't spend money on a new disc. Make sure the throwout bearing turns smoothly, but don't replace it unless it is not smooth.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-20-2023, 12:13 AM
