1989 3.2L rebuild
I’ve seen threads that address this but nothing recent that touches on cost. I have 118k on my 911 Targa and looking to rebuild the engine. Trans still shifts great and the clutch has only 4K miles on it.
Any thoughts on a 3.2 rebuild or 3.4L in regards to total cost? Not looking for a track car, just something to revive her given she looks good. |
what's driving you to rebuild your 3.2? I.e. what isn't working correctly that you're seeking to address? Top end only or split the case?
Senior Member
I will be corrected and stomped on if incorrect, but I think your options without splitting the case and machining the case are limited to rebuild at 3.2/3.3 or 3.4 with new P&Cs. If your compression gets to high, you may have to add twin plug ignition.
I have subscribed as I have the exact same mileage, but am planning on letting the engine dictate when this happens. Just want to have my poop in one sock and plan ahead.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
Ass-engine Nazi slot car -- PJ O'Rourke |
Senior Member
Jac - it is the PG version of "get your ***** in one sock" - meaning get organized and squared away. A US Navy slang for seabag is sock, so a VERY common phrase over my 20+ years. As in, "come on man, get your ***** in one sock..."
Racer
People don't ever equate "poop" with "stuff"....you can't just throw in another word for feces and expect it make sense....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 06-07-2022 at 11:31 AM.. |
118K mile you barely broken in the engine..in your case i`d say valve job which normal on 1987-89 with this or even lower mileage..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
On my second rebuild, the engine just needed a reseal and I wanted to upgrade the oil pump. I replaced all the bearings, gaskets, o rings, and what not, but all the major components were reused. I think it was around ~$4-5k. It's been a little while, so it may have actually been a bit cheaper. This does not include the heads being redone, which they needed on the first go around. I think Craig was charging around $100 per head to clean and rebush the valves.
Jonathan '79 Copper 911 SC '88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's |
You're making me add up my rebuild, haha. I did a full rebuild in 2018.
Heads: $1500 (new valves, machining, plus balance rods) Cylinder Nikasil Coating: $1000 ARP Studs: $575 ARP Rod Bolts:$200 Various EBS & Pelican Orders: $2000 I'm sure I'm missing a few things So the ~$4-5k range for a rebuild is realistic. This was all based on me doing the wrenching. It also doesn't include tools, engine stands, lift tables, etc. I would budget $6-6.5k so you aren't surprised. I didn't want to look at my previous receipts, haha. Thanks for that
The 9 Store
Prices went up in the last 4 years.
All used parts sold as is. |
Oh yeah, we don't talk about how much it actually cost.
In tools and equipment alone it was definitely like $5k. Granted that includes a two post lift and a tig welding setup, but still.
Sell your motor for $15K. ?!?!
Buy this engine for $27K: Rebuilt 3.2 engine for sale Your rebuild will have cost $12K. Your numbers won't match, maybe they don't already.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone Last edited by GG Allin; 06-08-2022 at 07:35 AM.. |
The only difference in rebuild cost for the 3.2 or 3.4 will be the pistons and cylinders. New Mahle parts at the high end, or to reduce cost new JE or CP pistons and machining/plating your cylinders. Should be able to estimate the costs from Pelican or EBS Racing online catalog. If you need new pistons and cylinders anyway it's an easy choice to make.
None of the above.
Your car is a is very special.It is the last of the finest of the Porsche 911 line.In 118 k miles there is no absolute need for any rebuilds!. If there was a valve job done on it already you are allset.If there is no white smoke on start up no need to worry.Why would you want to rebuilt it? As i said it is hardly broken in ..... Just drive it and enjoy it dude;-)..safe the money for gasoline;-)))) Ivan
The 9 Store
But even though I’m not an engine builder, I agree with the guys who say that yours probably doesn’t need a rebuild. Top end maybe. Have you done a leak down test? That would give you some great information to the health of your engine.
I do get some white smoke upon starting up.
QUOTE=proporsche;11713750]None of the above. Your car is a is very special.It is the last of the finest of the Porsche 911 line.In 118 k miles there is no absolute need for any rebuilds!. If there was a valve job done on it already you are allset.If there is no white smoke on start up no need to worry.Why would you want to rebuilt it? As i said it is hardly broken in ..... Just drive it and enjoy it dude;-)..safe the money for gasoline;-)))) Ivan[/QUOTE] |
High oil consumption (as in under 600 miles per quart of oil) is a good yardstick for when an engine rebuild might be needed. How many miles are you getting to a quart of oil? |
