911 SC gauges
Anyone used Speedhut gauges, if so what sizes, my car is at a shop being painted and I don’t have access to it
Old 02-19-2023, 05:32 PM
I use the Speedhut GR-5-156 4-1/2" Tach. It needs an adapter to fit nicely. See here:
https://forums.pelicanparts.com/porsche-911-technical-forum/917067-aftermarket-tach-install.html
I really like it. No more bouncy needle on shifts.
Rick
1978 911SC
Old 02-20-2023, 05:36 PM
send speed hut your old gage and they will install modern guts
great stuff
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 02-20-2023, 06:03 PM
PCA Member since 1988
I replaced all the gauges in my Ford GT with a Speedhut custom panel and I love it. If I was interested in going aftermarket on my olde 911 gauges, I'd definitely consider Speedhut. You can get gauges with red lights built in for shift points, low oil pressure, high temp, etc.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-21-2023, 11:47 PM
Contact jbell on this site and he makes custom gauges for you.
Old 02-22-2023, 05:32 AM
I asked them about this - they will not do this. Per Speedhut:
The only custom we can give you is indicator signals and high beam on the tachometer.
I've got two speedhut gauges installed in my car right now. A 4-1/2" Tachometer and a 4" GPS Speedometer. I had to 3D print an adaptor ring for my tach. (Please excuse how dirty everything is - was in the middle of cleaning up a lot of silicone and replacing my dash)
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 02-22-2023, 04:15 PM
