Analog Air Cooled
Body Guys, anyone ever seen this..
My 86 has Zero rust on it. One of the reasons I own it. I’m currently redoing the front end all pretty and I decided to stem clean the inside bits.
Right side A pillar. Inside fender I noticed a hard but pliable lump… All the others are hard? Any idea? Could my steam cleaner warmed it up? Looks like dragging OG sealer. I know Porsche went nuts in 86 w sealer and corrosion warranty. I’m gonna poke it when I get home. It’s not like it’s water. More like loose calling that’s not totally dry. Everything else is hard.
86 Targa 91 964 13 6 SPD Cayenne |
I hate to inform you but that’s rust. A very common area for rust. Check the other fender as well.
lake wales fla
If you push on it it will probably feel a little crunchy, hope I am wrong but it looks all to Familiar.
Richard |
Analog Air Cooled
Really eh? Well only one way to find out. Not crunchy at all though. Will report back.
Analog Air Cooled
Nope. Not rust and didn’t expect it which is why it’s so strange. No evidence of damage or repair. Hard shiny steel under this sealant. It’s like small bubbles off gassed fine giving a way to a big bubble. Like a Pizza crust.
Asking a very reputable official Porsche shop, and you folks ideas. It’s all level now. Thinking a sealer and airbrush in some red. ![]() ![]() ![]()
Cars and Cappuccino
Does it feel rubbery at all? Is it shutz?
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Analog Air Cooled
Yes very rubbery. Like bathroom calking. It’s the exact same texture where it’s thin all over the car. Rear, other side. Factory sealer stuff. You know how you can did a finger nail into any under coating on these cars.
Cars and Cappuccino
My guess is the car likely got a paint respray (inclusive of the wheel wells) at some point in its life that included spraying the paint over the "schutz" or "schutzen" (rubberized factory undercoating). The bubbling seems a little odd but if they put new schutz on first and then painted immediately afterwards it might have reacted. I mean it COULD have come from the factory that way but I doubt it.
https://www.3m.com/3M/en_US/p/d/b40071581/
Analog Air Cooled
I’m a pretty good car detective on this one. Re blasting everything and cerakoting the whole front end and plating, you notice every lil thing. It’s defiantly that schutzen. |
Porsche didn’t paint the undercoating, and putting new chip guard over old is a waste of time and money because it will never harden. Either strip to bare metal and epoxy or etch primer let it flash then new chip guard or shoot some primer and color over it and hope for the best or leave it alone.
Analog Air Cooled
Will do. It’s always better to check. Hearing that nice clank of hard metal and seeing shiny was a relief.
Analog Air Cooled
Well, It looks like my steam cleaning in the thick part raised up some Shuntz.. They did go thick in there in 86-89.........Now to prime, apply more to level it out and spray some Red.. UGh..
My car had something similar in the front where it was wrecked at some point and repaired. It was rubbery and scraped off easily. It was much less durable than the factory 3.2 Carrera undercoating (PVC?). Scrape it all off and redo it.
Analog Air Cooled
Plans to prime it and add more to it and colour. Every 3.2 I’ve seen has paint colour on the under coating. The wells, in the fenders and the bottom pan semi flash over. One pic I found on BAT the other is a friends 18k mile car. Same red paint over the coating. ![]()
The rubbery undercoating was sprayed on and even brushed on in some areas. These cars were far from perfect from the factory! I Unless its a concours car, I would treat the shiney area, tape-off, prep and epoxy prime your torn area, build-up with some undercoat (Upol or Wurth), let it dry/harden, spot paint and move on and enjoy!
RGruppe #180 So many cars.. so little time!! |
