-   -   '87 Intro...and Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/1134852-87-intro-questions.html)
mziggy16 02-14-2023 12:34 PM
Pelicans -
I've been a long time lurker and tire kicker, but finally acquired my first air cooled car...a Diamond Blue Metallic '87 Carrera. I spent the first week getting the car detailed to my exacting specs and getting familiar with driving it.
I've done a few maintenance items, including the addition of a dash lighting fuse. Next up is fluid exchanges, valve adjustment, headlight relay, etc. to get it all to a new baseline.
Anyway, I have two mysteries where I need some help:
1. While installing the dash lighting fuse I found two mystery wires (see below pic). The best I can tell is that these lead back to a bundle (wrapped in very old electric tape) and head towards the ignition.
2. Headlights and Dash Lights: When I pull the headlight switch about halfway, the interior lights illuminate and I can twist the knob to adjust brightness. When I pull the knob all the way out, the interior lights go out and the headlights turn on. So...I need to get both on at the same time...
I will also add that electric troubleshooting is not my forte, so I won't be offended by 3rd grade level explanations.
Thanks for any insight.
-Mike
http://forums.pelicanparts.com/uploa...1676406660.jpg
PeteKz 02-14-2023 10:25 PM
1. Yeah, those are definitely "aftermarket." You'll just have to trace them as best you can.
2. Probably the headlight switch.
tdw28210 02-15-2023 05:34 AM
Welcome. Very pretty car. Congrats. What Pete said. ^^^^^
mziggy16 02-15-2023 06:15 AM
I’m going to do my best contortionist impersonation today and see if I can trace those aftermarket wires back to the source.
As for the headlight switch, I have a decent understanding of how everything feeds in here. Is there a fix for this or is it just biting the bullet on a new switch?
Thanks for the help.
Cairo94507 02-15-2023 09:25 AM
Congratulations- great looking car. Were it me, I would remove any after market wiring and get the car back to the stock wiring harness. As pointed out already, those are definitely added on by a PO.
PeteKz 02-15-2023 01:01 PM
aGood chance they were for a radio installation.
Brtuffli 02-16-2023 11:01 AM
Did you trace it back? If so, where did it go. I imagine someone had a wiring diagram (colored) for an 87.
mziggy16 02-16-2023 02:53 PM
I was able to trace the green wire back to a tap into a green wire that goes into the ignition. The best I can tell is that the factory green ignition wire is the AC>DME wire (can someone confirm?).
The red wire is still obscured by hard-to-reach electrical tape.
http://forums.pelicanparts.com/uploa...1676587881.jpg
rokemester 02-16-2023 04:38 PM
Pretty car! Diamond blue metallic? Looks like the 88 anniversary edition color scheme. Congrats!
mziggy16 02-16-2023 06:40 PM
Yep, Diamond Blue Metallic over Marine Blue interior. Looks like an anniversary car but not an ‘88 and no signatures in the headrests.
Hotshot 02-17-2023 07:13 AM
Tell me the wire and I’ll look it up. Most of the wiring haven’t changed since 73. The 3.2 diagrams are better to trace in B&W online. The Sc and later current diagrams are better if in colour and your join all the pages up on a massive diagram.
You will quickly see what orig looks like and what’s aftermarket. Electrical is easy on these once you lean a few things. Most late 80s cars had a python or some BS immobilizer in them. For the love of all things holy rip it out. I’ve one almost burn a car down.
Getting it back to stalk is always the goal 30 year later. The good news is most mods are done just bad enough that they tie into a little bit of the real wire. So you have the OG colour.
The big go to’s are the main light switch and the ignition switch. Look benching ( seats out helps the neck ). The wire part ( brown ) pulls off the main unit. Look for splices into Red and yellow thicker wires. That’s normally the starting point.
mziggy16 02-17-2023 07:17 AM
The tap is on to a lime green colored wire that comes out of the ignition.
