sleeping_beast's Avatar
Question Tint removal or lexan replacement?
Hi,
The previous owner of my Targa did a terrible job at tinting the rear window. Without really knowing what I was doing, I removed the pellicule as much as possible. There was a first layer that came off really easy and I totally removed it. There is a second layer that seems very difficult to remove. Obviously, I'll need many hours of scrubbing with a razor blade.
I now understand that what I did might have been the wrong thing to do. It seems that the tinting pellicule has two layers. I learned that these layers should be removed simultaneously (using steam or ammonia) or the remaining layer will be very difficult to remove. I blew it.
As I mentioned, I'll need many hours of scrubbing with a razor blade to remove the remaining layer (unless someone has a better proposal). One alternative that could be interesting, is to take advantage of the situation to replace the rear window with a lexan version, as lexan replacement is usually nice for weight reduction. Is such a rear lexan window available for the Targa?
Thanks,
Alain
Gruppe B #666
'75 Targa
Duo Discus XLT
Old 06-04-2003, 10:08 AM
304065's Avatar
Not recommended for a street car--lexan scratches easily, no defrost, flexes a bunch (race cars have aluminum blow-out tabs affixed to the body around the perimeter, and many have two aluminum straps across the back to keep it from blowing out when you spin).
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-04-2003, 10:34 AM
rick conrath's Avatar
I went through the same thing.....but paid the window guy to remove the rear window to make the removal process easier. I had two layers to contend with. He used solvent (I think acetone) and a heat gun...not necessarily in that order though. Be careful with the razor blades that you do not damage the defrost filaments. Plastic scrapers might be better.
Rick
'78 930
Old 06-04-2003, 11:06 AM
I removed the tint from the inside of my windows with a heat gun--the kind you use to loosen paint, though of course I didn't need _that_ much temp. I hot hair dryer might work just as well. Just get under a corner of it somewhere and as it begins to loosen, keep "painting" it with the heat in a progressive pattern as you continue to lift it.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 06-04-2003, 11:07 AM
I feel your pain. I just removed the tining from all my windows and I hope I never have to do it again. For me, in some cases I found a heat gun blowing on the outside of the window loosened the tint enough to have it release without leaving too much goo behind. I will also second Ricks warning about razor blades and the defrost filaments, be very careful.
gary
Old 06-04-2003, 11:23 AM
Eric Coffey's Avatar
The most popular method of film removal seems to be spraying ammonia on the tint, then covering (taping) it with a black trash bag, and letting the car sit in the sun for a while. I haven't used that method, but supposedly the tint will just peel right off. I, like some of you, peeled the film off successfully, but was left with the glue residue. I used a product called "C64" Tint Glue Remover, and PPG "Acryli-Clean" (along with a few rags and razor blades) with pretty good results.
Old 06-04-2003, 11:51 AM
nice doggie
Hetmann's Avatar
I used laquer thinner with pretty good results. Messy but it worked. Good Luck!
Jerry
78 SC hotrod
02 Mini Cooper S
Old 06-04-2003, 03:38 PM
