charles
New momo wheel, horn not working
I installed a momo wheel with Porsche adapter on 73 911.
There is a gap between adapter and steering column and a bit of play in steering column if I move wheel up/down or side2side.
Horn does not work although I hear relay click, so the contact pin is making contact with copper ring on column.
Should adapter mate further down on column?
Suggestion for horn not working?
Old 02-17-2023, 10:46 AM
HarryD's Avatar
Did you transfer the spring and bushing on the end of the Momo Adapter?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-17-2023, 12:02 PM
charles
Harry
I did not have a spring or bushing on my original wheel.
The turn signal cancel tab on original wheel appears to be thinner than momo adapter, I’d have to pull momo off to know for certain.
Old 02-17-2023, 01:43 PM
charles
Perhaps I misread, the momo adapter did no come with a spring or bushing.
Pelican: MO-0230
Old 02-17-2023, 01:45 PM
charles
This is adapter I have
Old 02-17-2023, 01:52 PM
charles
Checked the turn signal cancel tab dimensions:
Original- 1mm thick
Momo -2mm
Here is picture of my steering column
Old 02-17-2023, 02:25 PM
Been here a while
Do you have that silver ring that’s in your reply, it gets installed under the horn button and between the wheel and the hub? The horn button has to be grounded to this.
looking for 1972 911t motor XR584, S/N 6121622
Old 02-17-2023, 02:48 PM
HarryD's Avatar
Originally Posted by chauser View Post
Harry
You need those two parts to keep the steering wheel from wobbling. The 928 sleeve will not work in the 1973 and older cars.
Harry
2020 MB E350 4Matic
Old 02-17-2023, 03:08 PM
HarryD's Avatar
For the horn, if you ground the brown wire in the column does the horn work?
Harry
2020 MB E350 4Matic
Old 02-17-2023, 03:09 PM
charles
I do have the grounding ring installed between wheel and hub.
I believe the copper loop (can’t see it in this picture) from horn button contacts the ring for ground.
Old 02-17-2023, 03:14 PM
charles
Harry
Harry,
On the backside of the wheel I have, there is no means to attach the turn signal cancellation/contact sleeve.
Wrong wheel then?
Old 02-17-2023, 03:17 PM
HarryD's Avatar
Harry
… snip ….
Harry,
Wrong wheel then?
The base of the adapter has the cancellation ring built in.
The silver ring goes between the momo wheel and the adapter. This provides the connection to ground. If you look at the horn button, there is a metal spring on the edge, this contacts the metal ring. You connect the horn ground to the horn button tab.
Harry
2020 MB E350 4Matic
Old 02-17-2023, 03:33 PM
charles
Harry,
I believe I have ground adapter ring, horn button set up correctly.
I think I need a different adapter to deal with steering wobble - do you know model# that would work.
Old 02-17-2023, 03:54 PM
HarryD's Avatar
This thread may be helpful. Weird Horn wiring issue (wire keeps breaking blinker cancel tab!)
Harry
2020 MB E350 4Matic
HarryD's Avatar
Harry,
You need the spring and bushing.
Bushing Part#: 695.347.725.00.
Spring Part#: 914 347 713 00
Harry
2020 MB E350 4Matic
Old 02-17-2023, 04:10 PM
charles
Ok, thanks Harry
I’ll order spring and bushing.
Thanks for links as well, I had been reading “the idiots guide”
Old 02-17-2023, 04:18 PM
HarryD's Avatar
Ok, thanks Harry
Glad to help.
Years ago I struggled with the same issues. I have several posts trying to help others.
Harry
2020 MB E350 4Matic
Old 02-17-2023, 04:24 PM
HarryD's Avatar
Mine has a gap as well. Do you hear the contact pin scraping against the horn ring?
Harry
2020 MB E350 4Matic
Old 02-17-2023, 09:26 PM
charles
Harry
I have continuity between the horn ring and the female pin that connects to the horn button.
When all assembled, if I press horn button I hear relay click, but no horn.
I’m going to reinstall original wheel today and test that horn works.
Thanks for checking on gap.
Old 02-18-2023, 03:44 AM
charles
Here is comparison of 65-69 vs 70-73 steering columns.
It appears I have been missing the spring (#13, 70-73) all along.
question:
is what I have indicated in pict as #12, the steering shaft bearing? It appears for 70-73 the sleeve is not used/required.
Old 02-18-2023, 05:17 AM
