fallingat120mph's Avatar
Vacuum connector question...
1986 911 Coupe here -
Looking for this part (yellow arrow):
...found this from Pelican and wondered if someone could verify this is the correct part/size? 4mm...
https://www.pelicanparts.com/More_Info/9P1129487.htm?pn=9P1-129-487-M253&bc=c&SVSVSI=0586
Some info I have found show it for later year models...
Cleaning up the engine and this part is obviously old and very rigid. Not the best seal.
Thanks everyone -
Erik
1986 911 Coupe
1986 911 Targa
Old 02-20-2023, 07:06 PM
That's fond- just deglaze
Hi Erik- That is the correct part number (4mm dimension) for an '86. The old part number for 1986 was 92857471702 (per the PET) and it has been superseded. As an aside, our host also sells the Porsche branded part...
https://www.pelicanparts.com/More_Info/9P1129487.htm?pn=9P1-129-487-OEM&KeepHeader=Y
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 02-20-2023, 07:33 PM
Hope this helps!
Saw it was superseded and ordered (branded part) early this morning -
Thanks for the verification and much appreciated!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-21-2023, 05:10 AM
Make sure the damper isn't leaking while your in there, mine just kicked the bucket and the engine is an '87. leaked gas into the vacuum causing hard start and rich mixture.
Old 02-21-2023, 05:21 AM
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-21-2023, 07:13 AM
