Windshield Rubber Seam Orientation
I'm wondering if the rubber windshield seal has an orientation - a top and a bottom. Currently, my URO V2 seal oriented so that the gasket seam is (mostly) centered at the top of the windshield. I haven't found a definitive answer in the many gasket threads - but some pictures/videos I've found show the seam at the bottom of the windshield.
Even after a lot of tapping and shaping of the aluminum trim - I'm still not terribly happy with my install - especially in the corners. I feel like I could push the window out without much difficulty. If the corners are molded with respect to the glass corner angles - this could explain my issue.
'85 911 Carrera 3.4 Turbo |
Original Owner
I installed this 911-541-225-04-M253 from our PP Host recently and the seam went to the center top. It fit better than what came out and sealed the corners just fine.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
