Vacuum connector question...
1986 911 Coupe here -
Looking for this part (yellow arrow): ![]() ...found this from Pelican and wondered if someone could verify this is the correct part/size? 4mm... https://www.pelicanparts.com/More_Info/9P1129487.htm?pn=9P1-129-487-M253&bc=c&SVSVSI=0586 Some info I have found show it for later year models... Cleaning up the engine and this part is obviously old and very rigid. Not the best seal. Thanks everyone - Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 02-20-2023 at 08:10 PM.. |
That's fond- just deglaze
Hi Erik- That is the correct part number (4mm dimension) for an '86. The old part number for 1986 was 92857471702 (per the PET) and it has been superseded. As an aside, our host also sells the Porsche branded part...
https://www.pelicanparts.com/More_Info/9P1129487.htm?pn=9P1-129-487-OEM&KeepHeader=Y Hope this helps!
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 02-20-2023 at 08:42 PM.. |
Saw it was superseded and ordered (branded part) early this morning - Thanks for the verification and much appreciated! Erik
1986 911 Coupe 1986 911 Targa |
Make sure the damper isn't leaking while your in there, mine just kicked the bucket and the engine is an '87. leaked gas into the vacuum causing hard start and rich mixture.
Thanks! Erik
