Will a plastic fuel tank from a 91 C2 fit into an 87 Carrera?
Thanks.
88 Carrera Coupe Gran Prix White 03 Harley Dyna Lowrider FXDL |
ANYBODY???? Will a C2 tank fit into an 87 Carrera???
No.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
No way. Here is a pic of a 964 tank.
Thank you...those bolt holes will definitely not line up!!! So much for that idea.
Too bad. The plastic tanks have a lot of advantages.
Grease Monkee
Yes yes I know this thread is old enough to drive...
I find it hard to believe the tank wouldn't fit in a G-body car. You would have to install a different frunk floor pan to fill the hole. But why wouldn't the 964 tank fit? Is there some other structural difference between 964 & 3.2 Carrera? Would be great to have the fuel tank inside the wheelbase as well as gaining some additional frunk luggage space.
86 911 Carrera Coupe 99 996 C2 Coupe (former) |
Mark
1979 911SC Targa |
Insert Tag Line HERE.....
The fuel lines /pump locations are also completely different.
Marc |
Grease Monkee
Trying to find a photo of the 964 body shell without the tank in it. It's not that I want a plastic tank. I'm intrigued by where/how it's mounted in the car (within the wheelbase) Plus it lends itself to more frunk space.
The 964 forum at Rennlist should have project photos with the fuel tank out, as you need to remove it to access the HVAC system.
Here is one: https://rennlist.com/forums/964-forum/1135829-restoring-my-92-964-cup.html#post15734797 And here: https://rennlist.com/forums/964-forum/538187-9m-restoration-of-kermit-1990-championship-winning-964-trophy-cup-7.html#post7848668 Mark
1979 911SC Targa |
Grease Monkee
There we go...
Unsurprisingly the body structure underneath the tank looks very different from a Gbody car. That answers my question Thank you
